Idle problem (I think)
Old Sep 13, 2006 | 11:31 AM
mintlaugh's Avatar
mintlaugh
Default Idle problem (I think)
Hello,
Wondering if someone can help, just over the last week or so my car Escort Si 1996 seems to be chugging, for example when I put the accelerator down when standing it splutters then revs up as normal and I've noticed when I drop into 2nd or any lower gear it judders then goes ok...
I've just moved in a new house so don't want to spend £100's and was wondering if someone could possible help
Many thanks
Old Sep 13, 2006 | 01:22 PM
Wardy257's Avatar
Wardy257
Check and clean the ISCV. If that does not help unplug the MAF and see if gets better. If it doe, check the electrical conections to the MAF and clean the inside with carb cleaner.
Old Sep 13, 2006 | 02:47 PM
mintlaugh's Avatar
mintlaugh
Thanks for reply sorry but can you just let me know what ISCV (idel control valve??!!?) and MAF (main air filter ??!!) stand for am so not mechanical minded just a lazy surf bum!!!!
Thanks again
Old Sep 18, 2006 | 12:05 PM
- Sim -'s Avatar
- Sim -
iscv i know it as iacv (idle air control valve) and
maf = mass air flow meter
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
