boost problems!!!!!!!!!!!!!!!!!!
Old Aug 19, 2006 | 07:47 PM
rstgreg's Avatar
rstgreg
Default boost problems!!!!!!!!!!!!!!!!!!
right im having a crisis im running a 2ltr zvh with efi head etc so running ofac fes turbo management was running 7psi on standard injectors fine but was told that i could run 14psi on standard injectors with a chip so on went the chip and a twist of the bleed valve but wen i accelerate its like im hitting a block come off the accelerator and straight back on and she hits 14psi fine so wot could be causing the block first of all??????????
anyone feel free to help plzzzzzzzzzzzzzzzzzzzzzzzzz!!!!!!!!!!!!!!!
Old Aug 19, 2006 | 09:31 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Just try lowering the boost very slightly. You may find that when you go in for boost at lower RPM it labours a little and forces the boost up, but doesn't make quite so much at higher RPM.
Worth a go.
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
