looms ofac / ofab
Old Aug 9, 2006 | 09:20 PM
gee1599's Avatar
gee1599
Default looms ofac / ofab
i'm fitting efi to my erst i have all the bits apart from the ecu the question is how can i tell if its a ofac or a ofab loom ??????????
also i have been told you need the correct type map sensor
how do you tell which is which ????????? please help
Old Aug 9, 2006 | 09:37 PM
RST Ski's Avatar
RST Ski
what colour is the big connector for the ecu?
Old Aug 9, 2006 | 09:48 PM
NEWTON's Avatar
NEWTON
Default Re: looms ofac / ofab
you can tell by the map sensor ofab has a webber marelli one and ofac has the ford digital one,id go for ofab personaly its more tunable
Old Aug 9, 2006 | 09:53 PM
gee1599's Avatar
gee1599
the plug is gray and it has ford on the map sensor??
Old Aug 9, 2006 | 09:54 PM
RST Ski's Avatar
RST Ski
thats ofac matey
Old Aug 9, 2006 | 09:56 PM
gee1599's Avatar
gee1599
whats better ofab or ofac wont to run apx 200bhp
Old Aug 9, 2006 | 10:08 PM
RST Ski's Avatar
RST Ski
i think the ofab map sensor can handle more boost than the ofac, but either is fine for 200bhp
my loom is ofac and my target is also 200bhp, been told beige injectors, 195chip, - actuator, should see me around that mark, mayb above it with a better intercooler
Old Aug 9, 2006 | 10:17 PM
gee1599's Avatar
gee1599
are you doing it to a erst and are you using a xr3i loom or a fiesta loom i see your in surrey just round the corner from me if you are using the frst loom how far are you into it ?????
Old Aug 9, 2006 | 10:34 PM
RST Ski's Avatar
RST Ski
yeh its on my s2, i finished my conversion about 4 wks ago, just doing the tunning side of it when i get some more money ive used the xr3i loom, i kept my mfi head and used a adapter plate to fit the inlet, ive got a early block on mine so i went for the sierra crank pulley way for the cps
Old Aug 9, 2006 | 10:57 PM
gee1599's Avatar
gee1599
i could not find a xr loom so im fitting the frst loom into my erst loom
Old Aug 9, 2006 | 11:01 PM
RST Ski's Avatar
RST Ski
did u mean the loom for the rest of the car or the engine loom?
Old Aug 9, 2006 | 11:03 PM
gee1599's Avatar
gee1599
just cutting in the engine part of the frst loom
Old Aug 9, 2006 | 11:09 PM
RST Ski's Avatar
RST Ski
I wired up the fuel pump and injectors and joined it to the ofac loom
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 24, 2015 11:11 AM
muz
Sep 30, 2015 08:29 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
