Help! - Car not starting
Old Jul 29, 2006 | 04:53 PM
DanS2i's Avatar
DanS2i
Default Help! - Car not starting
I have got an Escort Cabriolet with a Fiesta RS turbo engine.
The car is turning over but is not firing up, I can hear the fuel pump prime, but there doesn't seem to be a spark.
It seems to be an intermittent fault, for example it won't start then abit later on it starts fine and will run for a few days with no problems then it will stop again.
I have replaced the Crank sensor and tried another coilpack.
Any ideas???
Thanks
Dan
Old Jul 29, 2006 | 05:15 PM
steven botes's Avatar
steven botes
corroded earth wires?
Old Jul 29, 2006 | 05:18 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
dicky fuel pump relay?
Old Jul 29, 2006 | 05:20 PM
DanS2i's Avatar
DanS2i
If it was the fuel pump relay wouldn't the fuel pump not prime?
Old Jul 29, 2006 | 06:01 PM
ian r's Avatar
ian r
tried swaping the edis on the wing??
Old Jul 29, 2006 | 06:02 PM
DanS2i's Avatar
DanS2i
No I haven't, think I might need to swap that!
Thanks
Dan
Old Jul 29, 2006 | 06:11 PM
ian r's Avatar
ian r
i got a spare if u need 1
Old Jul 29, 2006 | 06:15 PM
DanS2i's Avatar
DanS2i
Cheers mate, though I think my mate might have one.
Though if it is that I might have it off you.
Thanks
Dan
Old Jul 31, 2006 | 07:49 PM
robert 123's Avatar
robert 123
have u tryed wigglin the wire that connects 2 the cps u may have a brake in the wire i had this problem on my car
Old Nov 29, 2009 | 10:09 PM
RST2CUSTOM's Avatar
RST2CUSTOM
mate did u ever sort the problem out? i got the identical thing on same car!!!!
JoeyBoyden
Jan 4, 2024 02:36 PM
Fordmad!
Sep 26, 2015 05:24 PM
Adam-M
22
Aug 10, 2015 10:46 AM
xr_craig
Aug 7, 2015 06:00 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
