brakeprob when fitted rearbrakes....
Old Jul 28, 2006 | 12:47 PM
JohanRS's Avatar
JohanRS
Default brakeprob when fitted rearbrakes....
hello,
I just fitted cossiebrakes in the front of the car and rearbrakes.... but now i have the following prob i don't have pressure... all the air is out of the systeem but i have the put the pedal 2 times down before i got pressure.... do you have any idea what this could be???
please help me
greets johan
Old Jul 28, 2006 | 12:51 PM
kjc300's Avatar
kjc300
Yes!! You need to unbolt the rear calipers and hold them on the disc with the bleed nipple upwards - then bleed them, they will bleed properly!!
Old Jul 28, 2006 | 12:52 PM
KSA-Cossie's Avatar
KSA-Cossie
Undo the rear calipers rotate them on the disc till the bleed nipple is at the top bleed them and refit .
kjc300's Avatar
kjc300
just to confirm, rear cossie calipers too??
Old Jul 28, 2006 | 12:53 PM
JohanRS's Avatar
JohanRS
no not cossie calipers
Old Jul 28, 2006 | 12:57 PM
JohanRS's Avatar
JohanRS
just phoned the guy who fit it but he has done it that way and still it is not good
Old Jul 28, 2006 | 04:05 PM
jonny stannard's Avatar
jonny stannard
DOES YOUR CAR HAVE ABS? IF IT'S AN ERST AND YOU DO HAVE ABS, YOU SOMETIMES HAVE TO HAVE THE PUMPS SPINNING TO BLEED THE AIR OUT OF THEM I.E START THE CAR UP AND WITH THE FRONT WHEELS IN THE AIR PUT IT IN FIRST THEN REBLEED THEM ALL.
ALSO YOU NEED TO HAVE THE REAR WHEELS ON THE GROUND OR THE SUSPENSION UNDER THE CARS WEIGHT SO YOU CAN BLEED OUT THE LOAD VALVES. I HOPE THIS HELPS?
JONNY
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
