home built cossie rebuilds?
From: learnin to build a yb lump properly in dennis's garage
how much could i be looking at to rebuild my currently running cossie engine if i sourced the parts and did everything apart from the machining work?
does anyone know whjat parts id need
appx cost of parts?
where do i start lol
appx cost of parts?
buy a block thats fooked and go from there tbh
gasket set is 300ish to 400, then the bearings are around 300ish, pistons are 500ish, rod bolts and head bolts 250ish machine work about another 250 ish then another 500 for sundrys i guess
thats when it all goes well i guess
usually theres gonna be " ill buy another clutch, then ill buy new cams, then ill rebuild the head then oooo i know ill go and buy qiup ect, then fuel pump then then then then then then then then then
then you sell it 3 month later and buy a newer car with aircon
depends on the spec Grant, for a standard rebuild, pistons, rebore, crank grind shells, gaskets etc with a group a or cometic gasket you should be able to do it for about a grand.
I rebuilt my bottom end with rebore new pistons, reground crank, skimmed flywheel, new oil pump all gaskets including cometic head gasket and an alcon clutch for Ł1250, but I did shop around for parts and picked a lot up from shows to get showprice discount.
Hope that helps.
Hope that helps.
you'll need all new bearings and thrust washers(big end/mains/small end),new oil pump and possibly pick up pipe,gasket/seals set,new pistons and piston rings,defo have the head rebuilt by a pro,will stop most of the common cossie smoke probs,maybe have turbo rebuilt too.
obviously machine work on top of that too,but i did mine for less than Ł2000,using all genuine parts,some sourced cheap from GGR on ebay....big ends,small ends and mains cost me less than Ł100
TPM961
Jan 15, 2018 10:50 AM
Thanasis
Sep 7, 2015 07:33 PM
