fuel pump wire
Old Jul 22, 2006 | 11:31 AM
THE RADMAN's Avatar
THE RADMAN
Default fuel pump wire
im about to rewire my fuel pump on the esc cos,is 17.5 amp cable ok?
Old Jul 22, 2006 | 11:51 AM
lamb chops's Avatar
lamb chops
Yes should be fine, try and get a some big strand stuff if you can.
Old Jul 22, 2006 | 11:54 AM
Ryan's Avatar
Ryan
go for slightly larger say 25 amp.
as chops has said, dont go loads of fine strands, but dont go for a few thick ones.
something like 19/0.3 or something like that.
Old Jul 22, 2006 | 12:04 PM
lamb chops's Avatar
lamb chops
Thanks Ryan
Old Jul 22, 2006 | 12:43 PM
R4N SS's Avatar
R4N SS
this is something i need to do too.
Ryan where's that seatbelt holder dude?
Old Jul 22, 2006 | 12:54 PM
Ryan's Avatar
Ryan
i got it here mate.
pm me your address.
Old Jul 22, 2006 | 01:38 PM
THE RADMAN's Avatar
THE RADMAN
cheers guys
Old Jul 22, 2006 | 01:55 PM
THE RADMAN's Avatar
THE RADMAN
is the thinwall type of cable ok?
Old Jul 22, 2006 | 02:33 PM
Ryan's Avatar
Ryan
yes thinwal is fine, as long as its good quality cable and a good enough amp and strand rating then it will be fine
Old Jul 22, 2006 | 07:13 PM
THE RADMAN's Avatar
THE RADMAN
will this do ref25? http://www.vehicle-wiring-products.c...es.html#gen533
Old Jul 22, 2006 | 07:51 PM
DazC's Avatar
DazC
17.5a is a bit on it's limit and will result in voltage drop over a distance.
2mm thin wall would be sufficient but protect the wiring as there isn't much insulation to protect the copper. 2mm thin wall is usually 28 strands at 0.3mm thick and is rated at 25a.
If you want thick wall cable then go for 4mm rated at 35a, 65 strands at 0.3mm, or 3mm rated at 27a, 44 strands at 0.3mm.
Old Jul 22, 2006 | 08:02 PM
Ginge !'s Avatar
Ginge !
just finding my feet
ran cant you just make them looms and sell em aswell mate
would make our lives SOOO much easier
Old Jul 23, 2006 | 11:22 AM
THE RADMAN's Avatar
THE RADMAN
what i dont understand is that you can buy 17.5 amp 28strand x0.30mm and 25 amp which is 28 strand x0.30mm,how come one is higher rated when they both seem identical?
Old Jul 23, 2006 | 11:25 AM
xr4x4rs's Avatar
xr4x4rs
id imagine the 17.5 will be a thicker copper wire to handle the current
Old Jul 23, 2006 | 12:26 PM
Eagle's Avatar
Eagle
Super Moderator
i used some 2 guage from halfords excressive i know .. but rather have a good supply than just making do
Old Jul 23, 2006 | 12:38 PM
THE RADMAN's Avatar
THE RADMAN
both seem to be the same guage thats what i cant understand
Old Jul 23, 2006 | 12:40 PM
Graceland's Avatar
Graceland
Team HOTHOT!
this is what I used when I re-wired my pump
Used the same stuff on the BMW too
Old Jul 23, 2006 | 12:56 PM
DazC's Avatar
DazC
The reason is that the thin wall cable can dissipate heat into the atmosphere quicker than the standard thick wall cable. It stays cooler at a higher current draw than the thick wall equivelent.
Old Jul 23, 2006 | 05:30 PM
Ryan's Avatar
Ryan
ginge, i probably could do mate.
will see in the future, bit busy at the moment wit other stuff
i suppose i could do a kit but you can buy the kits for about Ł30-40 if i remember rightly.
Old Jul 23, 2006 | 06:46 PM
THE RADMAN's Avatar
THE RADMAN
that makes sense then, cheers
Old Jul 23, 2006 | 07:00 PM
DazC's Avatar
DazC
I's not worth making the loom for that price. I know it's a kit and it needs assembling but I certainly couldn't make a pump loom around that price ready made.
Old Jul 24, 2006 | 07:18 AM
Ryan's Avatar
Ryan
i know mate, doesnt seem worth it does it.
Old Jul 24, 2006 | 07:55 AM
Franco's Avatar
Franco
Ryan how much to sort mine pump out? IE get rid of the dodgy wires at the back?
PM me & let me know dude! Make it worth your while when you pop up to do Pauls!
Old Jul 25, 2006 | 03:40 PM
THE RADMAN's Avatar
THE RADMAN
right ,got the wiring sorted, just need to know where is best place to take an ignition feed from? im taking a live direct from battery to relay and want an ignition controlled feed to the relay also
Old Jul 25, 2006 | 03:52 PM
Eagle's Avatar
Eagle
Super Moderator
use the original wire to the pump ...
Old Jul 25, 2006 | 03:53 PM
Ryan's Avatar
Ryan
as pete has said use the original fuel pump live as the trigger.
Old Jul 25, 2006 | 04:12 PM
THE RADMAN's Avatar
THE RADMAN
dont want to do that as i want to have all new wiring to eliminate the old wiring problem
Old Jul 25, 2006 | 04:15 PM
Eagle's Avatar
Eagle
Super Moderator
then you will have to run a seperate wire from the fuel pump relay at the front of the car to the pump at the back as the switch...
Old Jul 25, 2006 | 04:23 PM
THE RADMAN's Avatar
THE RADMAN
ill start again,lol, fused live from battery to relay,live from relay to pump,earth from relay to ecu,earth from pump to battery,just want an ignition controlled one to relay if that makes sense?
Old Jul 25, 2006 | 04:26 PM
Eagle's Avatar
Eagle
Super Moderator
yep .. if you do not want to use the old wire as the trigger you will hav to run a seperate wire from the fuel pump relay to trigger it ... ignition control will leave it switched on constantly...
Old Jul 25, 2006 | 04:34 PM
THE RADMAN's Avatar
THE RADMAN
the ecu controls it by switching the earth
Old Jul 25, 2006 | 04:44 PM
Eagle's Avatar
Eagle
Super Moderator
oh well always knew i was in the wrong
JK12
33
Apr 26, 2021 12:09 PM
jonjg
Sep 1, 2015 03:46 PM
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
