zetec turbo fuel pressure regulator ? need advice please.
Old Jul 15, 2006 | 11:51 AM
jason len's Avatar
jason len
Default zetec turbo fuel pressure regulator ? need advice please.
just a quick question guys as i need your help.
i have built a 2.1 zetec turbo useing bosch 382cc 803 green injectors
what i want to ask is i currently dont have a fuel pressure regulator on the engine, should the car still fine start without one??
anyone please help
Old Jul 15, 2006 | 11:53 AM
You dont have a regulator AT ALL?
If its does run fine it will mean you got very lucky choosing the fuel return pip size
Old Jul 15, 2006 | 11:57 AM
jason len's Avatar
jason len
no mate.
the 2 pipes from and the return to tank are connected either side of the fuel rail.
i just wanted to know if if would start without a fuel regulator, untill i get hold of one.
just wasent sure if it would stop it from starting?
Old Jul 15, 2006 | 12:01 PM
No it wont, unless by some miracle the return pipe is small enough to cause pressure in the rail, but it would be dangerously lean if that happened.
Dont try to start it without a regulator
Old Jul 15, 2006 | 12:03 PM
jason len's Avatar
jason len
oh ok mate so i take it it wont start without one,,
we did try getting her started but she wouldent even attempt to fire, also we noticed there was a smell of petrol, like it was flooding??
Old Jul 15, 2006 | 12:06 PM
Without a regulator there is almost zero pressure in the fuel rail, so i dont see how it could be flooding as it will rely on vacuum from the engine to draw petrol through the injectors.
If it did fire it would run VERY lean, melted piston anyone?
DO NOT TRY AGAIN YOU BODGING CUNT
(no offence intended )
Old Jul 15, 2006 | 12:08 PM
Speedy Gonzalez's Avatar
Speedy Gonzalez
chip-3door
PMSL@ no offence intented
Old Jul 15, 2006 | 12:10 PM
I'm meant to be more polictically correct these days
Old Jul 15, 2006 | 12:11 PM
Speedy Gonzalez
wouldn't worry mate no else is on this forum!
Old Jul 15, 2006 | 12:12 PM
jason len's Avatar
jason len
lol no offence taken
we also noticed the fuel pump is not priming, uselly its 2-3 secs before it goes off when ignition is switched on, but we noticed the fuel pumps on constant. guess this might be why because there is almost zero pressure in the fuel rail, could be wrong, but you can def smell petrol once its been cranked over a few time.
(dont worry wont be trying that again till i get a regulator)
unless the flooding is due to the megasquirt setup.
guess im gona need one of these
http://cgi.ebay.co.uk/Adjustable-Per...QQcmdZViewItem
Old Jul 15, 2006 | 12:14 PM
Personally i would use the Webber one as fitted to cossies as standard.
Old Jul 15, 2006 | 12:17 PM
jason len's Avatar
jason len
them dial regulators are good as it tells you the pressure, however quite expensive.
whats the webber one like just a small type regulator.
Old Jul 15, 2006 | 12:18 PM
Jim Galbally's Avatar
Jim Galbally
agree with chip, waste of money, just use a standard one off a cossie or similar.
oh and if yourte wondering WHY there's zero pressure in the fuel rail, just draw a diagram of your fuel system and you should work it out quite quickly
Old Jul 15, 2006 | 12:20 PM
Speedy Gonzalez
the webber is good enough to go on a cossie so it'll be good enough for your car mate
Old Jul 15, 2006 | 12:22 PM
jason len's Avatar
jason len
ok, just looked on fleabay this was the only one i could see off a scorpio cosworth http://cgi.ebay.co.uk/FORD-SCORPIO-C...QQcmdZViewItem
this the right one??
if so how do u fit them ass you can attach a pipe one side ok but think other side suppost to fit in manifold. which is no good for me as i have a custom manifold with fuel rail so i need a inline one.
Old Jul 15, 2006 | 12:53 PM
No, thats the wrong one.
Old Jul 15, 2006 | 12:54 PM
Here is what a standard cossie one looks like:
http://i7.photobucket.com/albums/y25...2_65DT8236.jpg
Old Jul 15, 2006 | 01:45 PM
jason len's Avatar
jason len
cheers mate for the picture,
can i use another regulator off a diffrent car as i need one pretty quick and theres none on ebay.
Old Jul 15, 2006 | 01:48 PM
Ginge !'s Avatar
Ginge !
just finding my feet
please stop tpuching the car until you graps what the fuel reg does
even i can work out why theres no presure
please please please read a little more then go from there
potentially as you are mapping it yourself, you can use ANY regulator that is designed to work with positive pressure, so any turbo one basically.
Old Jul 15, 2006 | 01:49 PM
Ginge !'s Avatar
Ginge !
ps dont crimp the pipe for presure either !!!!!
Old Jul 15, 2006 | 02:07 PM
jason len's Avatar
jason len
what do think about these mate
http://cgi.ebay.co.uk/Pressure-Regul...QQcmdZViewItem
or somethink like a fse
http://cgi.ebay.co.uk/Rover-turbo-fs...QQcmdZViewItem
rs turbo
http://cgi.ebay.co.uk/Escort-RS-turb...QQcmdZViewItem
Old Jul 15, 2006 | 02:16 PM
Stu @ M Developments's Avatar
PassionFords Creator
Mate, buy a 2wd cossie one. Soem of that crap your looking at may not be rising rate, thus it will fit and idle, but when you come on boost you will have massive fuelling problems.
It must be rising rate.
Old Jul 15, 2006 | 02:18 PM
Ginge !'s Avatar
Ginge !
mate theres a fuel presure reg in parts for sale mate with a plished rail for 40 quid that shorty is selling
sorted
think i got a spare one somewhere too aswell but its in me garage and i try not to visit there
Old Jul 15, 2006 | 02:27 PM
jason len's Avatar
jason len
thanks b19bal,
i have snt him a pm, i take it these cossie regulators its just 1 pipe from injector rail & other pipe return to tank?
Old Jul 15, 2006 | 02:28 PM
Ginge !'s Avatar
Ginge !
yeah and the on epn the top to the inlet manifold
Old Jul 15, 2006 | 02:31 PM
jason len's Avatar
jason len
cool, am i going to need the cossie rail? as i already have a custom rail, or will i need it for the cossie regulator mate?
Old Jul 15, 2006 | 02:34 PM
Ginge !'s Avatar
Ginge !
the cossie reg attaches to the rail with a pipe of pipe on each end so in thory no you dont but i aint seen how your reg is attached
Old Jul 15, 2006 | 02:38 PM
jason len's Avatar
jason len
b19bal, sent you pm mate.
Old Jul 15, 2006 | 04:23 PM
Jim Galbally
or try any of the breakers, im sure theyve got a few
41
Aug 21, 2015 06:47 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
knight19770
Aug 4, 2015 12:36 PM
turbobill
Aug 1, 2015 08:55 PM
