mains/ oil pump issues
Old Jul 9, 2006 | 08:26 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
Default mains/ oil pump issues
ok had this engine for a while, when it 1st started it would be spot on but after a minute it would lose oil pressure (lamp flickering) and after a few seconds of this it would get a tad growly (not knocky but just noisier)
now i figured its gonne need a grind and some shells (like the other 4!!! engines in my shed ) but since ive taken the caps off the shells and almost perfect as is the crank, im happy to leave them in as they look good but that brings to to my 1st question
the shell (pic) seems to be over 1 side a bit too much, you agree??, its located propperly in the indent, while im on the subject the top shell is grooved but the lower 1 is solid, this right?? been a few months since i stripped a cvh and i cant remember
seems to sit further 1 side than teh other huh
and viewed the other side
top shell groved
and as for the oil pump, its fooked hence im hoping that while it caused a drop in pressure it will also be the cause of the noise thus the lump will be fine with a new un fitted
engines been together for very few miles so dont wanna split the head off or have the crank messed with too much as its recently been done
Old Jul 9, 2006 | 08:28 PM
1.9 xr2 on 40's
st170 breaking
the wear on the pump is like a series of razors its worse that the others ive got piled up, and they say cvh pumps are reliable
Old Jul 10, 2006 | 06:29 PM
gee1599's Avatar
gee1599
whats the bigs like??
Old Jul 10, 2006 | 07:47 PM
1.9 xr2 on 40's
st170 breaking
spanking georgous, like new
JK12
33
Apr 26, 2021 12:09 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
