car wont turn over stater getting very hot
Old Jul 3, 2006 | 11:07 PM
ford crazy's Avatar
ford crazy
Default car wont turn over stater getting very hot
89 s2 turbo wont turn over fast anoth tryed a new battery starter is getting very hot and seems to be draining battery any ideas
Old Jul 4, 2006 | 07:31 AM
HORNETS7's Avatar
HORNETS7
have u put on another starter?
starters can break down internally and u get a short like u say this will drain the battery
try another starter
Old Jul 5, 2006 | 07:05 PM
steven botes's Avatar
steven botes
the bush on the gearbox end is either worn out , or has been knocked out
if you remove the bottom plate on your box , feel behind the flywheel for this bush , it should be buggerd!
with the bush out ,the rotor shorts on the stator , causes a short and works erratically .do this enough and youll be replacing the battery soon enough!
Old Jul 5, 2006 | 07:06 PM
steven botes
Old Jul 5, 2006 | 07:56 PM
bigmatt-s2rst's Avatar
bigmatt-s2rst
sounds fooked mate, ive had 4 rs turbos and messed with second hand starters
ive just put a brand new motorcraft starter on my s1 tonite
£120
well worth it tho, summer only car so prob last forever!!!
The Underdog
29
Sep 7, 2015 09:49 PM
tankybaby66
Aug 9, 2015 07:13 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
