Car wont start
Old Jul 1, 2006 | 06:03 PM
Shandy-Ade's Avatar
Shandy-Ade
Default Car wont start
Yesterday i had a gearbox fitted by mr.clutch, they then took the car round the block to try the gearbox out, they then switched it off, and it wouldn't start again, dodgy starter motor, they fitted a new starter motor and all was fine until this morning, it just turns over, i took the starter motor out and i could turn the teeth by hand, so rang mr.clutch who said when it engages with the flywheel it will lock up, so took there word for it, i took a spark plug out and it's sparking, i put the car in gear and it bumps never started tho.
Any ideas??
The car is a fiesta turbo
Thanks
Old Jul 1, 2006 | 07:39 PM
haz87's Avatar
haz87
check the gearbox earth strap is connected
Old Jul 1, 2006 | 07:52 PM
Shandy-Ade's Avatar
Shandy-Ade
If that's the cable that bolts onto the gearbox via the starter, then that's earthed fine as when i had the starter out i checked the connection, if it's something else let me know so i can check that
Old Jul 3, 2006 | 10:59 AM
HORNETS7's Avatar
HORNETS7
did u say it turns over but wont fire?
or wont it turn over either?
did u say u can bump it but it still wont start?
they aint knocked the crank position sensor have they?
JoeyBoyden
Jan 4, 2024 02:36 PM
Fordmad!
Sep 26, 2015 05:24 PM
Adam-M
22
Aug 10, 2015 10:46 AM
xr_craig
Aug 7, 2015 06:00 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
