adjusting cossie fuel reg to work on a zetec?
Old Jun 23, 2006 | 10:41 PM
luke89's Avatar
luke89
Team HOTHOT!
Default adjusting cossie fuel reg to work on a zetec?
right im not sure if i need to adjust my 2wd cossie fuel reg on my zetec engine on throttle bodies its running ST170 injecters im sure the car it come from was running stage 3
thanks
Old Jun 24, 2006 | 07:05 AM
abdr500's Avatar
abdr500
i would cheack to see if the fuel presure is to high or low dont just leave
it
Old Jun 24, 2006 | 10:57 AM
luke89's Avatar
luke89
Team HOTHOT!
how can i check if its high ? lol
Old Jun 24, 2006 | 11:24 AM
DazC's Avatar
DazC
You need a fuel pressure gauge, the knowledge behind what pressure the ST170 is meant to run, what fuel flow you need to get the correct AFR for you engine, and also if your pump and wiring can handle what you ask of them
Old Jun 24, 2006 | 12:51 PM
Jim Galbally's Avatar
Jim Galbally
theres nothing special about the reg, should work on any EFi car
Old Jun 25, 2006 | 12:30 PM
luke89's Avatar
luke89
Team HOTHOT!
bttt surly some one nose what presser i need ?
Old Jun 25, 2006 | 12:44 PM
Luke, as you have a car that is totally non standard in terms of hte management the asnwer to what pressure you need is whatever it was mapped at.
but personally i would recomend around 3 bar
Old Jun 25, 2006 | 12:49 PM
luke89's Avatar
luke89
Team HOTHOT!
thanks chips will sort out my edis agen and have a little try when i got some petty in it lol
Billy_RS
16
Oct 11, 2025 09:41 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
