escort fuel pump relay!!!
Old May 30, 2006 | 01:24 PM
carlosb_st's Avatar
carlosb_st
Default escort fuel pump relay!!!
any ideas on location???
Old May 30, 2006 | 03:21 PM
THE RADMAN's Avatar
THE RADMAN
what sorto f escort?
Old May 31, 2006 | 09:06 AM
SafeChav's Avatar
SafeChav
On the assumption its a MK3/4 MFI, the relay is up under neath the drivers side of the dash, a pinky purple colour.
Old May 31, 2006 | 09:19 AM
carlosb_st's Avatar
carlosb_st
its a mk4 rs turbo
Old May 31, 2006 | 09:22 AM
SafeChav's Avatar
SafeChav
As above then
Alvyn's Avatar
Alvyn
Originally Posted by carlosb_st
its a mk4 rs turbo
as above then m8
Old May 31, 2006 | 09:24 AM
carlosb_st's Avatar
carlosb_st
cheers lads, any ideas if its not that.
fuel pump does not cut in on turning ignition on
Old May 31, 2006 | 09:26 AM
SafeChav's Avatar
SafeChav
Does the car run though? Just the prime you have lost?
Old Jun 2, 2006 | 08:10 AM
carlosb_st's Avatar
carlosb_st
the car cranks over and has spark and fuel but wont run. we looked for the relay ad the only one we found was a black one in the speaker hole. any more helpful information would be great?
Old Jun 2, 2006 | 09:56 AM
SafeChav's Avatar
SafeChav
Is the pump running then if you say you are getting fuel?
Can you even see a pink plug up in the same place as they black one?
Old Jun 2, 2006 | 10:01 AM
carlosb_st's Avatar
carlosb_st
THE BLACK RELAY IS ON PURPLE PLUG AND TUCKED BEHIND THE SPEAKER.(DRIVERSIDE)
Old Jun 2, 2006 | 10:02 AM
SafeChav's Avatar
SafeChav
Thats the fuel pump relay then, you probably find its a lucas relay........with a pink bottom in it.
Does the pump run?
Old Jun 2, 2006 | 10:04 AM
carlosb_st's Avatar
carlosb_st
THE PUMP RUNS WHEN WE POWER IT WITH A POWER PROBE
Old Jun 2, 2006 | 10:20 AM
SafeChav's Avatar
SafeChav
ok
In that case, remove the relay, and bridge a wire from the from the Red to the Black/Red (the red is permenantly live so be careful), the pump should run, then try and start, if it does then its obviously the relay faulty.
Old Jun 2, 2006 | 10:26 AM
carlosb_st's Avatar
carlosb_st
CHEERS FOR YA HELP ON THIS M8, ILL LET U KNOW HOW IT GOES
Old Jun 2, 2006 | 10:27 AM
Dave Henshall's Avatar
Dave Henshall
the above sounds like a good approach to eliminate whether its a relay fault or not, they do fail and are fairly common so it is a prime suspect
Old Jun 2, 2006 | 10:36 AM
SafeChav's Avatar
SafeChav
No problem
Dave Henshall are you back at home yet?
Old Jun 2, 2006 | 10:40 AM
Dave Henshall
next 2 weeks we reckon, the plaster is coming on monday for his second week so it will be after next week i reckon
Old Jun 2, 2006 | 10:41 AM
SafeChav's Avatar
SafeChav
Excellent
Can you send me those microcat instructions then please?
Old Jun 2, 2006 | 10:44 AM
Dave Henshall
hey i've got the instuctions here at work actually, whats your email address
Old Jun 2, 2006 | 10:46 AM
SafeChav's Avatar
SafeChav
its in my MSN button
Old Jun 2, 2006 | 10:49 AM
Dave Henshall
sent
Old Jun 5, 2006 | 01:35 PM
carlosb_st's Avatar
carlosb_st
CHEERS LADS, BIGGER PROBLEM NOW, THE OIL LIGHT IS ON, WE PUT NEW PISTONS IN AND HAD THE HEAD SKIMMED. WE GOT IT RUNNING THANKS TO U GUYS, WENT TO THE PUB TO CELEBRATE, THEN GOT BACK TO WORK ON IT ON SAT, AND THE OIL LIGHT CAME ON, WE HAD RUNNING IN OIL IN IT AND I KNOW THAT CAN SOME TIMES CAUSE THE LIGHT TO COME ON DUE TO THIN OIL, SO WE DRAINED IT AND PUT 10/40 IN, IT WAS FINE AND NOW BACK ON YET AGAIN,
ANY IDEA'S?
Old Jun 5, 2006 | 01:37 PM
SafeChav's Avatar
SafeChav
Ive said it before and ill say it again, spending Ł30/40 on a good oil pressure gauge is one of the best investments you can ever make
Glad you got it running, gay the oil light is on though
Old Jun 5, 2006 | 01:40 PM
carlosb_st's Avatar
carlosb_st
I DID TELL HIM, LOL
ORDERED A SWITCH HOPING IT WILL CURE IT,
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
