Saff cossie 4x4 plugs
Hi guys going to put new plugs in my saff 4x4 cossie running 330 bhp, currently has agpr12pp8 in just wondering what you would use
About the same stage as you, but i use it only on track, so some cold apgr701c's gapped @ 0,65mm for me
look also on here
https://passionford.com/forum/viewto...ighlight=plugs
look also on here
Originally Posted by p_jay78
I do...
On my old stage 3 they were gapped down due to the boost blowing out the spark
are these the plugs thats listed for escort cossies ,heard a lot of peeps mention that before on the 2wd saffs ??
I have the ngk irridium (spellin
Originally Posted by millsyscossie
Originally Posted by KSA-Cossie
Motorcraft 071 plugs m8 finis code 1120834.
Do u ru n these plugs gapped down kev ???
I do...
Hi guys have just fitted QC57C plugs on recommendation but was told to expect lumpy tickover is this true and has anyone else had this ?
Its a very good plug mate so if you can put up with the lumpy start its worth it, alot of people go for c59`s but i`ve been told that there not that good for a 330/350 brake cossie, more a 220 brake rst engine kind of plug
Use platinum tipped Motorcraft PP8's in my cossie, running similar spec as you.
DixieTheKid
Jul 23, 2023 10:16 AM
Anutternutter
Aug 21, 2015 06:07 PM
mrmann
Aug 20, 2015 11:24 PM
