taking apart the driveshaft
Old May 7, 2006 | 03:39 PM
Arjan's Avatar
Arjan
Default taking apart the driveshaft
hi all, does anyone know how to undo a driveshaft? i wanna clean them and put new grease in.
there should be a circlip(ford workshop manual and haynes)of some kind to prevent the 2 parts from slipping off? their holding on to each other in some way,most likely within the bearinghousing? but theres no way obviously to get in there. any ideas? thx in advance!
Old May 7, 2006 | 04:03 PM
yzfr1boy's Avatar
yzfr1boy
u need circlip pliers to open the clip out then they either pull out or tap off
Old May 7, 2006 | 04:25 PM
SafeChav's Avatar
SafeChav
Right.......if you look into the CV joint, the flowery looking type bit thats on the spline, will have a little "opening" in one place, the clip is in there.[
As yzfr1boy boy said, circlip pliers are good here, i dont have any and have undone numerous CV's with a pair of needle nose pliers although its fiddly (bad enough with the right kit )
You have to open the clip to release the shaft
Old May 7, 2006 | 04:28 PM
Rick's Avatar
Rick
there's actually 2 opening
U will prob have to rotate the circlip before it's opening lines up with one of the openings in the shaft. Make sure alll the greace is out, as u wont see it.
It's tricky if u havent done it before. It's easier if one person uses the circlip pliers to open the clip, while another taps it off.
Old May 7, 2006 | 04:32 PM
SafeChav's Avatar
SafeChav
Thats wierd, definately 100% only one on all the ones ive done myself And all the ones ive done have had those queer circlips that dont have holes to lock into, just upturned ends, but because of what they are have never been out of line??? Must be a variation on them
I've also never had to tap one off they all have just pulled out very freely.
I agree though.........DEFINATELY easier to have one person tugging while you open her up (sorry)
Old May 7, 2006 | 04:40 PM
Rick's Avatar
Rick
lol, mine have always needed to be tapped, and yes - they are upturned ends - but not enough for it to stop twisting round. Defo 2 openings on mine
Old May 7, 2006 | 04:44 PM
SafeChav's Avatar
SafeChav
Wimp
Tap that ass
I'll check in a minute just incase mine do have 2 openings......look like a prick if they do.
Old May 7, 2006 | 04:55 PM
Arjan's Avatar
Arjan
thx alot guys,will give that a try!
A.t.p
Oct 23, 2015 07:54 PM
Fudgey
21
Sep 30, 2015 06:19 PM
dojj
Sep 29, 2015 10:32 PM
mondeomark
Sep 28, 2015 06:28 AM
