Cold starting help needed????
Right lads got touble starting my car from cold it starts but i have to keep my foot on the revs or it will cut out once its warm it ticks over fine so has any of you had this before????
Originally Posted by safechav
NO not cold start valve at all................got nothing to do with it
Could be a few things to be honest, u got a boost/vacuum gauge?
Originally Posted by DazC
Have you got a fuse in your heated seats slot in the fuse box?
Whats the gauge reading when you first start it, and is it stable or all over the shop?
Realistically i think its going to be as Daz mentioned..........but its always worth asking.
When your holding the revs does it sound like its idling smoothly or does it sound rough? And is the gauge stable then?
Daz mentioned about checking the fuse in the slot labelled up as the heated seats.
JoeyBoyden
Jan 4, 2024 02:36 PM
Archiejay
Aug 12, 2015 12:07 PM
