EEC4 TB/ISCV & Antilag ???
I don't think he is Basky.
Just a thought Lee. If the EEC 4 one can't be used/modified then you could just get a fitting for the end of the normal ALS/idle valve which just has 2 push on pipe fittings.
Originally Posted by markk
lol , your not allowed als
I'm sort of hoping i'll need it when the tyres are on
These extra valve ideas are cool and i will certainly look down that path if the eec4 ones cant be done,
Lee
My iscv is already used for anti lag (kenny mapped it with an antilag file etc) allbeit very mild (approx 3-5psi increase due to the iscv and tb being standard) i'm actually wondering if it is possible to machine/modify for a greater increase like the traditional valves and tb can be?
Lee
Lee
is it fully open when its being used ? i would have though a fair bit of air might flow through them ?
you couldnt really make the valve flow anymore air because of its internal dimensions really.
is it fully open when its being used ?.
Lee
Tay69
Jan 16, 2007 02:19 PM
Feb 20, 2006 11:37 PM
39
Feb 20, 2006 03:49 PM
