How would you monitor fueling with this fitted?
Old May 2, 2006 | 11:06 AM
GARETH T's Avatar
GARETH T
monitor it before the bypass!
Old May 2, 2006 | 11:14 AM
foreigneRS's Avatar
foreigneRS
Testing the future
my view is that afr should be measured closer to the engine than the tailpipe (e.g downpipe) unless you have a very sophisticated device.
essentially you are right.
Old May 2, 2006 | 12:29 PM
Rick's Avatar
Rick
Some are, some aren't. Exhaust probes react far too slowly for proper mapping.
Old May 2, 2006 | 12:34 PM
le-claw's Avatar
le-claw
Thats interesting.
Mine has never had any issues using this method.....
Blew up twice from a dyno map....
LOL
Old May 2, 2006 | 12:38 PM
Stu @ M Developments's Avatar
PassionFords Creator
How do you work that out? Do you realise how fast teh gas travels the length of the car? As long as your using a device capable of measuring and displaying oxygen leaks, the tailpipe is a perfectly good place to sample under most conditions. If however a screamer or alternative bypass device is fitted, you need to measure prior to its manifold connection.
Old May 2, 2006 | 12:41 PM
Rick's Avatar
Rick
They travel quiclky up the exhaust pipe, but the gas analyser reacts quite slowly, and won't show u misses etc? I don't mean a clamp with lambda sensor in the tailpipe btw.
Old May 2, 2006 | 12:43 PM
le-claw's Avatar
le-claw
Thought thats what you were replying to LOL.....how the fuck can u map a car with a gas analyser ?
Old May 2, 2006 | 12:46 PM
Jim Galbally's Avatar
Jim Galbally
dingy, you never been to a "normal" rolling road then the sun machine is normally there with the CO% reading healthy
Got ya, i thought you were saying sampling from teh tail with a lambda was wrong. Sorry.
I could name you 10 well known ones, all in teh UK, that do exactly that Steve.
Old May 2, 2006 | 12:52 PM
le-claw's Avatar
le-claw
Sorry, but the ones I have seen are a bit huge to sit on the passenger seat whilst driving flat out.
Honestly didn't know you could get small ones for live map's.
IMHO RR's can't be used for full map's anyway, and most roads don't come with a 240v power supply
Old May 2, 2006 | 12:55 PM
Most use rolling roads, but a few i know use something like this.
I evaluated the one above for the local SUN dealer. The pump was far too small to be of any use IMO.
Old May 2, 2006 | 05:09 PM
Old May 2, 2006 | 05:52 PM
ballin's Avatar
ballin
isn't that essentially just a screamer pipe?
Old May 3, 2006 | 06:56 AM
Originally Posted by Matt J
yes I spose, but my question was how do you get a basic setup done on a rolling road if you've got one of these halfway down the exhaust?
I answered your question in my first reply Matt.
Old May 3, 2006 | 06:59 AM
Cam's Avatar
Cam
I see ATP are now on V3.0 of their valve. I had a V2.0 and it worked for about 170 miles but fair play to ATP they refunded my payment minus a 10% surcharge.
borboyous
Aug 22, 2015 11:17 AM
kosienutter
31
Aug 22, 2015 09:55 AM
3doorcozmess
Aug 21, 2015 11:17 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
ekjim
Aug 17, 2015 08:57 PM
