Remapping
Old Apr 20, 2006 | 12:31 PM
Rob84's Avatar
Rob84
Default Remapping
When a Naturally Aspirated engine receives a remap, along with a free'r flowing air filter and cats back stainless exhaust, does the torque increase proportionally with the horsepower?
Rob
Old Apr 20, 2006 | 12:41 PM
Jim Galbally's Avatar
Jim Galbally
horsepower is a calculation of torque vs rpm
therefore you cannot increase the power without inceasing the torque.
it may not increase the PEAKS, but it will increase at some point in the rev range.
normally when you're increasing peak BHP you're pushing the torque at the top end of the rev range up
Old Apr 20, 2006 | 12:42 PM
Varies massively, sometimes you just end up with more power because the torque curve is extended up the rev range further, but with little or no change in peak torque, somethimes the torque increases quite a lot.
Old Apr 20, 2006 | 12:45 PM
Rob84's Avatar
Rob84
obviously on a screamer like most honda VTEC's, I can understand the torque increases being fairly minimal, but what about on a 2.5ltr, straight 6, 24 Valve, BMW M54 engine thats pretty torquey to begin with (180lb/ft vs 190bhp)
Old Apr 20, 2006 | 12:47 PM
If the volemtric effiency of the engine at the point of peak torque is currently hampered by the standard exhaust and filter or if at that point in the rev rnage more timing is safe then YES it will increase, however if its mapped well to begin with and the standard exhaust and filter are well suited to the engine at that point in the rev rnage then gains will be none or slim or MAY even be losses!
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Nov 1, 2015 06:53 PM
Oranoco
12
Oct 2, 2015 02:18 PM
Sp3no
Sep 27, 2015 07:23 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
