Shocking dizzy cap
Passion for Fords!
My 4x4 saffy has a new grp a coil, cap arm, and leads, when you touch the dizzy cap when the car is running it gives you a cracking shock, enough to make both arms jump!
Is this normall? i have never known it before,
The only other thing i have noticed is that when i look at the rotor arm, its only got a burn mark in one corner, not across the whole face as you would normall expect, Any ideas?
When i set the timming up, i aligned the phase sensor with the lug on the dizzy shaft, the timing is non adjustable anyway, the car runs fine.
Originally Posted by JTECHSAFF
surely there is a reason why its doing it, can touch dizzy caps all the time and never get shocks.
Originally Posted by TurboShed
I think it's pretty safe to say that what this means is that you shouldn't touch your dizzy cap again when the car is running.
dont think you should get a shock off it i can put hold the dizzy on mine ok when running........
touch it,you know you want to
when you set the timing,there is a notch in the dizzy body,which the contact on the rotor arm points to (when set to TDC )
not sure why it's shocking you but i'd change it, oh and touch it again
Passion for Fords!
i set mine so when its at tdc, the phase sensor under the rotor arm lines up with the second lobe on the dizzy shaft. the rotor timing is non adjustable the ecu adjusts itself.
you should set it so that at tdc with both cam pointers facing each other the pointer on the aux shaft should be pointing at the dot on the cover and the rotor arm should be lined up with the groove in the dizzy body.
if you don't get the rotor arm position right, how's the spark going to jump from it to the correct terminal on the cap to fire the correct cylinder in sequence?
the phase sensor position is related to the rotor arm, so get that right and you're away. there's more chance of the rotor being directly in line with the post in the cap at the right time then, so less liklihood of it jumping elsewhere and giving you a shock
Passion for Fords!
when you say line the rotor arm with the groove in the dizzy body, what groove do you mean? the big one that the plastic flash protector sheild sits into? If you mean that one i tried that and it doesnt even think of starting, so i aligned the phase sensor as before and
Passion for Fords!
i havent got any probs with my car it runs fine,
im doing over 500miles a week at the mo,eating porsches daily
i just wondered how people set the timing up, as i was told to do it differently to everyone else it seems
see pages 3 and 4 of the manual under this link
http://www.siipicossu.com/manuaaleja...Sierra%20C.pdf
the whole manual can be dowloaded from there, along with loads of others.
a little knowledge can save a lot of money with these bloody cars
SMILER258
Sep 28, 2015 09:04 AM
