Head gasket gone................
Old Apr 2, 2006 | 08:30 AM
churchy's Avatar
churchy
From: Out Shooting Burgelers, cause thats what Norfolk people do!!!
Default Head gasket gone................
Hi all,
I have been told my head gasket is on its last legs, but considering its done 75k on the std one it is probably due a change anyways. My question's are :
1. What is the recommended gasket to go for (car is running stg 3 340bhp)? Is the group A sufficiant?
2. Apart from a light head skim, is any thing else required, i.e extra seals, gaskets etc..... to do the job? It has just had an oil/filter change and cam belt.
3. How big a job is it to do for a garage, do you need to know cossies inside out, or is it no different from changing any other gasket?
Please help, I've just spent 5k on new turbo, brakes, suspension, alloys and still can't drive the bloody thing, and the garage that done the work can't fit it in for the head gasket
I want to drive my car
Its a saff 4x4 BTW
Old Apr 4, 2006 | 09:28 AM
churchy's Avatar
churchy
Yes, no?
Old Apr 4, 2006 | 09:38 PM
JjCoDeX75's Avatar
JjCoDeX75
Hi m8
I tend to take my engine to pieces an awful lot, so have become a bit of an expert on the matter LOL!
I am running a similar level of power to you at the mo, and to be honest, I managed to blow a Group A gasket in record time (10k) but I am pretty hard on the car. If you want a bit of extra security, then you might want to go for a Multilayer gasket. I went for the Cometic one. Not generally considered to be the best, but reasonably priced compared to the Genuine WRC multilayers. I have bascially been very pleased with it, though you need to ensure that both block and head are very flat, as it is not as tolerant as normal gaskets. DONT USE ANY SEALANT WITH THEM. I made this mistake, and cost me a gasket. Lesson learnt.
As far as the job is concerned, I have a 2WD, but all is generally the same.
To take head off the cosworth is generally considered to be an easy job provided you know the best way to go about it. The easiest way is to take off the head complete with the exhaust manifold, inlet manifold, tubro etc complete, and then dis-assemble on the bench. This is how I do it, and it saves a bucket load of time.
The problem is that the head cannot be skimmed with inlet valves left in place, and this makes the job a little more time consuming. As such you will need to use a special tool (valve spring compressor) to remove the valves on the inlet side only. This will mean a bit more of a job than just taking head off.
Once skimmed, it is really a matter of putting it back together in reverse order, making sure everything is as it should be. The rules for cossies is the same as other cars. All surfaces need to be suitably prepared and left in good order before re-assembly. Also, you need to know the tightning torques, order of bolts etc.
In addition to the Gasket, I would suggest the following:
Either new head bolts or pref. ARP Stud and Nut Kit
Inlet Man Gasket
Exh Gasket
EGT Gasket
Thermostat Housing Gasket
Cam cover Gasket
Cambelt
I would also strongly recommend that you replace as a minimum valve stem seals on all 16 valves. This is a job that requires the head to be removed to be carried out, and you will kick yourself if they fail later on. Also check valve guides.
If money is an issue, and you have some experience with engines, then you could consider taking the head off yourself, taking it to a friendly garage, to strip head, do necessary work including skim, then re-fit yourself! (making sure that all torques are correct)
This is by no means a definative guide to changing the head gasket, but should give you an indication of what is involved!
JJ
Old Apr 4, 2006 | 10:25 PM
churchy's Avatar
churchy
JJ, you are indeed a legend
I hope you don't mind if I PM you if I need anymore help mate
Old Apr 5, 2006 | 03:13 PM
JjCoDeX75's Avatar
JjCoDeX75
Hi m8
I dont mind at all!
If you decide to get more involved, then let me know. I have a copy of the Ford manual in electronic format, which you should have by your side. This details how to do the job, and also all the torque settings etc.!!
CheeRS
JJ
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
pie-face
Sep 15, 2015 10:43 AM
