zetec turbo question
Old Mar 30, 2006 | 06:32 PM
FULLBORE's Avatar
FULLBORE
Default zetec turbo question
could someone please tell me what needs to be modified to fit calibre turbo (c20let) pistons to standard zetec rods????
If the calibre turbo(c20let) pistons would fit EAGLE STEEL RODS????
if i was to get the standard rods SHOTPEENED and fitted arp rod bolts,what sort of power would they handle?????
cheers people
Old Mar 30, 2006 | 07:59 PM
Number1's Avatar
Number1
i think you have to bore out the gudgeon pin hole on the con rods, with eagle rods i presume if there custom then you could get anything you wanted, do you use the calibra pistons in the 1.8 or is that for 2.1? im not sure myself?
Dave
Old Mar 30, 2006 | 08:12 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
hi mate yes its for 2.1 zt
it depens on what series of zetec engine that u use
it has to be a silver top to be able to use std rods due to length of rod and yes its just the pin hole that needs modded
hope this helps
tommy
Old Apr 1, 2006 | 02:08 AM
jason len's Avatar
jason len
i wanted to know the exact same question as im currently building one myself 2.0 calibre turbo(c20let) pistons
surely if you can get the standard zetec rods for silvertop machined to fit wouldent it be the same process on steel eagle rods??
however maybe someone would know.
Old Apr 1, 2006 | 07:22 AM
JesseT's Avatar
JesseT
From the top of my head, the later zetec has a smaller diameter gudgeon pin. As the Eagle rods are for the later one they would also have hte smaller pins. The difference between the later zetec and C20LET pin diameter might be far too big to correct by machining
Old Apr 1, 2006 | 07:30 AM
FULLBORE's Avatar
FULLBORE
its gonna have to be a matter of buying the rods,and seeing the differences(and praying) it can be machined to fit!!! if not,i'll have to order up some je pistons
Old Apr 1, 2006 | 08:15 AM
FULLBORE's Avatar
FULLBORE
anyone know what size the rods need to be bored out to,so the the calibre turbo pistons fit???? in mm if possible????
AND what sze the original rods are as standard??
this way i can find out the spec of the eagle rods and work out if they will fit or not
Old Apr 1, 2006 | 12:09 PM
jason len's Avatar
jason len
looks we we both need some answers lol as were building the same engine, and both of us are contemplating steel rods however they wont come cheap
im still looing around, if you find out any more info please update this thread
i have heard people getting 300bhp with standard rods, forged pistons & apr bolts.
not sure what size the rods need to be, but the little end of the rod needs opening out to allow the calibra turbo gudgeon pin to fit, The Goodgeon pins used on LET pistons is slightly larger, so the small ends of the zetec rods need to be enlarged to suit.
think this is correct rod sizes
B/END 49.895mm
S/END 13/16
CENTRES 136.180mm
Old Apr 1, 2006 | 06:02 PM
FULLBORE's Avatar
FULLBORE
EAGLE steel rods are very cheap mate!!!!!!!! $318 for a set!!!!!!! thats around Ł180!!!!! after shipping and import tax etc i bet you would have them at your door for under Ł300!!!!!!
I emailed them earlier to see if they would make me a custom set. i asked for them to be the same spec as the standard rods found in the silver top zetecs, but the small end made to fit the 21mm wrist pin for the calibre turbo pistons
Eagle rods have been known to see up to 600bhp without failure!!!!!!!! That sounds good enough for me
i'll let you know how i get on
Old Apr 1, 2006 | 07:49 PM
graemewelch's Avatar
graemewelch
the conrod need to be remed out to 20mm i think and 10 thou machined off each side of the conrod. if you take conrod and gudgeon pin to any machining shop they will di it for you. hope this helps
Old Apr 2, 2006 | 01:24 AM
jason len's Avatar
jason len
rightstuff
see your close to my neck of the woods mate
let me know what eagle say mate
Old Apr 2, 2006 | 09:52 PM
FULLBORE's Avatar
FULLBORE
will do mate
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
