judder
Old Mar 29, 2006 | 09:29 AM
b14dave's Avatar
b14dave
Default judder
do you get bad clutch judder on pull away from a 6 paddle alcon
Old Mar 29, 2006 | 12:19 PM
Alvyn's Avatar
Alvyn
on which car?
I dont on my stage 3 saff if that helps
Old Mar 29, 2006 | 01:21 PM
b14dave's Avatar
b14dave
sierra sapphire cossie replaced clutch with alcon 6 paddle and std pressure plate had flywheel skimmed and got judder on pull away
Old Mar 29, 2006 | 02:28 PM
boost mad's Avatar
boost mad
clutch aligned properly ?
Old Mar 29, 2006 | 04:31 PM
Alvyn's Avatar
Alvyn
that would only stop the gearbox from going on as the splines wouldnt be in line,
how many miles have you done since it was fitted? may be yours needs a few miles to bed in? although I have fitted many without the probs you seem to be getting with a 6 plate NOW if it was a 4 plate I'd say grin and bear it!
Old Mar 31, 2006 | 02:01 PM
b14dave's Avatar
b14dave
done bout 500mls its only on pull away after its fine,did use one of them clutch aligning tools so should be lined up
Old Mar 31, 2006 | 02:37 PM
Dave Henshall's Avatar
Dave Henshall
it might need a bit of stick just to get it to face up properly... and they do take a bit of getting used to, you find yourself trying too hard to make it smooth and end up overcompensating on the movments of your foot, i get a similar thing driving a car with very light pedals (compared to the cossie) the brakes are super sharp and the throttle with the slightest tough makes the car rev to what it sound slike nearl flat out, wheras the throttle pedal ona cossie is very progressive imo and u can hold it any any revs even in nuutral without over revving...
Old Mar 31, 2006 | 03:56 PM
jon@work's Avatar
jon@work
the judder is more pronounced if you've got a bit of play in the prop or driveshaft CVs
martynhomer01
14
Sep 23, 2015 12:23 AM
Mark Mawson
Aug 31, 2015 07:09 PM
gabbo
Aug 28, 2015 03:56 PM
Archiejay
Aug 12, 2015 12:07 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
