my engine wont go in my car !!!!!
Old Mar 19, 2006 | 05:59 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default my engine wont go in my car !!!!!
its pissing me off but the fucker wont go in, the flywheel just sits flush with the bell housing but wont go further
is that deffo clutch aint center or are all cossies a bith at that point
any tips as today ive also found out my alpine screen with navigation, amp and subs have been nicked from the car too and ive not caught it on camera either
just want the car running so i car sell the fuking thing and give up on cars as it feels like when you get 1 thing almost sorted another problem happens
so back on the cossie engine, would it be easier to remove the gearbox and then refit after or not ?????
please help me
Old Mar 19, 2006 | 06:04 PM
dave cos4x4's Avatar
dave cos4x4
as long as the clutch is lined up then it should go in.
just turn the spline a bit to line it up,should work as long as everything is ok.
sorry to hear about the ice.
Alvyn's Avatar
Alvyn
get a sucket and rachet on the bottom pulley put gearbox into a gear and turn the pulley slightly and see if the splines of the box will line up with the clutch!
Old Mar 19, 2006 | 06:05 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Try rotating the engine crank (manualy) whilst you push it onto the gearbox.
Its an arse to fit mate....patients is required...did you take the engine out with it ingear?...If you did it makes it easier to get it back on....aslong as its still ingear..LOL...You will get there in the end!
Old Mar 19, 2006 | 06:12 PM
Ginge !'s Avatar
Ginge !
never took the engine out in gear, but its a new engine anyway so that may not have helped
is it any easier to get the gearbox on after its fitted as im temped to get the engine stuff in and then just fit the box or am i causing more issues for me
i even bought a clutch alignment too today and took out the engine and restarted but that done bollox all too
but even if the car is running at central day i got no tunes either now
my just tow the ar to work and take the S60 to sentral day,no fucking hassles then
Old Mar 19, 2006 | 06:13 PM
Ginge !'s Avatar
Ginge !
is it easier with a 4 poster ramp do you know
Old Mar 19, 2006 | 06:19 PM
Cowboi's Avatar
Cowboi
have u tried asking it nicely yet ginge?
Old Mar 19, 2006 | 06:22 PM
Ginge !'s Avatar
Ginge !
the way i feel now mate i think ill just break it and sell up
what do i need a ar for these days,i do nothing but work and when i go to use a car something fucking happens to it
company car i car drive and dump
Old Mar 19, 2006 | 06:27 PM
Cowboi's Avatar
Cowboi
try going through the gears as well mate when its in there. sometime can make it pop in ive heard.
bounch it about a bit and try and rock the gear box up and down a bit.
u did put the clutch on the right way didnt ya?
Ginge !'s Avatar
Ginge !
thats a bit late scotty, ive hsd me car broken intoand prob 2500k worth of stereo nicked and a engine that dont go in me car thats prob set me bak 3k in total
not to mention i snapped me amal vavle and part fo me fuel line last night
all i need now is the missus to tell me shes pregnant again to complete the day
but how you been matey, you gonna be comming ceantral day mate
Old Mar 19, 2006 | 06:30 PM
Ginge !'s Avatar
Ginge !
clutch is in the right wat as theres only 1 way it can go,,,,,,,,, not to mention im not a idiot
it just wont go and the crossmember done fuking help either
i miss wanky fwd cars now
You have to really wriggle it from side to side etc etc...be firm Ginge
Old Mar 19, 2006 | 06:35 PM
Ginge !'s Avatar
Ginge !
ive wriggled it, taken it out again, spat on it, called its mum a slag
it wont fuking go in, serious to it aint budging at all
Old Mar 19, 2006 | 06:58 PM
SPADGE's Avatar
SPADGE
Ginge have you stabalised/lifted the box with a jack? Remove the rubber engine mounts until you have the box and engine mated! Nothing else i can suggest as they normally just fall on with a bit of a wiggle
Old Mar 19, 2006 | 07:05 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
It'll go in, just persevere!
Ginge !'s Avatar
Ginge !
ive raise the bell housing mate and the engine mounts aint on it
it just wont wiggle past there
Old Mar 19, 2006 | 07:08 PM
SPADGE's Avatar
SPADGE
Get someone to turn the crank slightly using a 24mm on the bottom pulley whilst you are wiggling then. I take it you have made sure the box and engine are on the same angle? Failing that go and eat a few Weetabix and try again lol
Old Mar 19, 2006 | 07:11 PM
Ginge !'s Avatar
Ginge !
done all that too
think ill take it to work and get the master tech to fit it instead
spadge do you know what the multiplugs at the front of the car on the driverws side are for onn the main car loom,,,,,,,,,, ive just noticed em and i cant think what there all for right now
Old Mar 19, 2006 | 07:15 PM
SPADGE's Avatar
SPADGE
done all that too
The only multiplugs on that side are for abs pump and that side headlight there isn't anything else that i can think of there
Old Mar 19, 2006 | 07:20 PM
dojj's Avatar
dojj
Resident Wrestling Legend
have you tried to put the engine in place without the mounts on?
that way you can get a bit more movement out of the engine side to side to slip it all into place
you can put the mounts on afterwards or even get underneath and undo the gearbox mount to wiggle the gearbox into place
and are you doing it all on your own or have you got a few friends to volenteer their services for an afternoon?
Old Mar 19, 2006 | 07:36 PM
SPADGE's Avatar
SPADGE
Ginge just a thought
Have you checked the spiggot bearing in the end of the crankshaft to make sure it isn't in pieces? Don't fill the hole in the middle with grease either as that won't help!
Old Mar 19, 2006 | 08:43 PM
PeterLucas's Avatar
PeterLucas
not read all ya posts mate so not sure if you have actually sorted this or not . . . .
I put and engine is a cossie recently and found that if you put a little scissor jack under the box to raise it slightly, leave the box in gear and spin the flywheel with a leaver bar (whilst wiggling the box in) it will slide right in. . . . .asumming clutch is properly lined up . . .this can easily done by eye though mate
Goodd luck
Old Mar 19, 2006 | 09:03 PM
whitecossie's Avatar
whitecossie
also mate i would take the clutch off and try it on ya gearbox incase the teeth are wrong had a old rover like that before ,
JoeyBoyden
Jan 4, 2024 02:36 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
knight19770
Aug 4, 2015 12:36 PM
Old ford
Jul 31, 2015 06:50 AM
