leaking inlet maniiold gasket QQ please
recently I have had a hesitation problem and a holding back problem I have now found the fault I hope. would a leaking inlet manifold gasket cause a hesitation problem oh its on a 2wd cosworth
Ollie6RS2
it sounds promising . my problem was i just lost power and had a hesatation problem wher it would jerk a few times befor picking up and even when it started going it didnt feel right .realy hope this is my problem
my one is popping a little. and some times whistle and my boost has also dropped from 2bar to 1.6 I sprayed crab cleaner on my suspected area and the revs went up .a new gasket and a plenum spacer would do me nice
changed gasket and it fixed my air leak. but the hesitation problem is still ther it does it low rev and when flat out other wise if just crusing the its fine its like i get to pops then fine agine every time i lift of the throttel
GUZZLER
because that has all ready be done befor i did the conversion i have booked it in to go back but only for a set up to be sure its ok. this only started happining only last week its some thing stupid but need to sorte it. the plugs are perfect in coulor Basky
Basky
i gaped them to see if it helps it did stop the back fireing a littel but problem is still ther
the tps is my suspect back not 100% suer what do you think
Originally Posted by abdr500
MARCOSWORTH
i have changed the gasket i solved one problem but the main fault is still ther i am gona try new plugs and go from ther
Mc5506
Oct 5, 2015 09:57 PM
