HELP!!-just changed sump gasket, now RS wont idle !
Old Mar 15, 2006 | 04:53 PM
Lincolndanny's Avatar
Lincolndanny
Default HELP!!-just changed sump gasket, now RS wont idle !
HEEEEELP RS had a oil leak so this evening i dropped the sump and changed the gasket. Started her up, she idled for about a minute then cut out. so restarted it and it wont idle, just coughs and then cuts out What the hell have i done? car revs as normal just wont idle.
when i did the job, i removed the starter, droped the exhaust down, drained the oil, removed the sump, refitted the sump with new gasket, refitted starter motor, bolted the exhaust back up, filled up with oil and that was that. It doesnt leak oil (yet ) but cuts out
please help with some ideas someone
cheers
Danny
Old Mar 15, 2006 | 05:16 PM
Rick's Avatar
Rick
It's not sealed properly - have u checked all breather pipes are on properly, that u've not knocked one? The crank case is connected to the metering head via the breather pipes. So if something isn't sealing, it will suck unmetred air in and run lean and stall.
Old Mar 15, 2006 | 05:17 PM
Lincolndanny
Bugger cheers rick
Old Mar 15, 2006 | 06:14 PM
MikeyXR2i's Avatar
MikeyXR2i
Aye sure does sound like a vacumm leak on da biatch. One bit of air sucking in and these things won't idle. As said check all pipes are not loose re-check sump for leaks etc.
TPM961
Jan 15, 2018 10:50 AM
little bram
Sep 21, 2015 02:50 PM
marky_g
Sep 12, 2015 04:26 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
