Advice needed please (speed camera) & pot hole :(
Top & bottom of it is - i've just been flashed by a speed camera, i know the cameras there as i pass it quite often but my speedo's been playing up recently like it works for a while then it jumps about all over the place so you cant get a correct reading!!
I reckon i was probably about 4 mph over if that (40 mph dual carriageway) i didnt think i was speeding at all.
So basically is there anything i can do to get out of it or is a case of having 3 points on my clean license?
Then about 2 mins after that i hit a fookin hugh pot hole in the road & kerbed my rim
Not a good day
(can i claim against the council for my damaged rim)?
Thanks people.
Thanks people.
you will need to back to the pot hole, stick a ruler in and take a pic to show the depth, its gotta be about 6cm deep i think before you can claim
i cant remember
as for the sppeding, if you wernt that far over you may not hear from them, if so it will say your indicated speed
i cant remember
Think you can claim against the council for the rim. but you need pictures of the pot hole etc with a ruler in it so they can see how deep it is. Don't think anything can be done about the speeding ticket as they could say you shouldnt of been driving if your speedo doesnt work properly or something
Sorry mate
yes you can claim against the council mate just remember to keep receipts of the alloys and work carried out to fix it and you should take pics of the damage and the pot hole before you claim just incase the council fix the pot hole!
as for the camera did you smile!
only messing did it flash once or twice if once your fine if twice pray its a dummy!
goodluck
Cheers,
Hardeep.
only messing did it flash once or twice if once your fine if twice pray its a dummy!goodluck
Cheers,
Hardeep.
Not good news AJ
iirc correctly if your speedo doesn't work properly your car is seen as not road worthy (Or something long them lines)
Take lots of pictures of the pothole as Dan has recommended, also use a measuring device as it gives the picture some scale!
Good luck
Good luck
Thanks for the advice people - the speedo only plays up now & again, it's been working fine all day
Right it looks like i'll have to accept the 3 points then
No more clean license for this driving instructor
Singh - no i didnt smile i was cursing like fook
I'll have to go back to the place with the pot hole with a ruler & camera then (should i take a copy of the newspaper to proove the date)?
If you do get a NIP throught the door then use the PACE statement instead of their stupid forms and this should end up with the case being dropped.
PACE statement can be found on http://pepipoo.com
Originally Posted by Snowy_Astra
10% of 40 = 4
If you are absolutely certain you were doing 44MPH you've got nowt to worry about.
They allow a 10% margin of error that all speedos have.
Snowy_Astra
So your allowed 10% but if it flashes does that mean your over the 10% allowance or do they calculate it after they look at the pic?
-scar-
What's pace mate?
-scar-
What's pace mate?
It shouldn't flash unless you're over the full amount. Like I said, unless it's changed very recently it's 10% + another 2mph you're allowed. So 46 in a 40. But your speedo should be a good few mph out so if you got flashed for 46 i'd expect your speedo to be over 50 (if it was working)
Wait for the NIP, If its not there in 14 days, you're off scot free
As for the 10% + 2mph, not really sure about that TBH. I can't see it being right as motorway limits are 70mph, so that would be 77mph + 2mph = 79mph. I know people who have been done at 80mph.
You get done at 79mph so 80 is a no no. Basically the 10% + 2mph is the point at which you get done. So 35 in a 30 is when you get flashed. The 10% +2mph info was directly from a traffic cop so make of it what you will. I know its supposed to be changing to something different soon though
How well do you know this traffic cop?
I know mate. Sorry if I made it sound like i thought you were.
Very well mate.
Very well mate.
As for knowing the copper, thats ok then. i thought you got told by some random when you got pulled
Very well mate.
Very well mate.
I just hope the camera flashed someone on the side it was on & not me (the camera was on the opposite side of the dual carriageway) but there was lines on my side too.
So if i dont hear anything within 14 days it should be ok?
So it was 2 lanes away from you? Was it the normal gatso type camera?
Personally mate i'd say i'm 99% certain that the camera couldnt have got you from that far away. I don't think they can see the white lines on your side of the road as the angles are all wrong and it needs the white lines to work out your speed.
If there was cars on the otherside of the road I should think it was one of those that set it off. And you're in the clear. All fingers crossed mate I reckon you'll be fine. (touch wood)
Originally Posted by Adrian
Little Fella
If the GATSO went off while you were going towards it then you are fine.
& rofl @ little fella
Yup
Even if lines.
I gone towards one at well in excess of the limit in the early hours with lines on my side of the road.
Camera gone off and nothing.
This was 2 years ago.
Even if lines.
I set the one off on dereham road near the garage one night going towards it. No lines though. I found out later that night that one of my mates had spoken to the guy who set it up that day and he had been f'ing and blinding that the sensor had been knocked out of alignment so it was pointing on the wrong side of the road
AJ don't ever rely on your speedo reading for anything, a high percentage of them aren't callibrated properly anyway and especially the Jap ones. My speedo reading on the Evo is 5-6mph out compared to the GPS reading on my Road Angel. On a Mitsi Pajero I had, it was 10mph out.
On the cossie with 17" wheels the reading is 3mph out, but with 18" wheels the speedo matches the GPS reading.
AH you didnt say you were DRIVING TOWARDS IT
if so they cant do fuck all mate.
i got flashed by a camera i was driving towards while overtaking at slightly more than the limit
heard nothing and it was fookin ages ago
Speeding is an absolute offence - that means that there is no legal margin but the Association of Chief Police Officers agreed the 10% + 2mph guideline some time ago. They don't all follow this guideline though, and margin of error on a speedo isn't a defence either.
If we want to change this, we need every driver in the country to spend a day or two 10% under the posted limits and watch the country grind to a halt!!!!
As for the damaged alloy, the council is only liable if they can be shown to be negligent - ie they knew the pothole was there and likely to cause damage, but did nothing about it. If they can argue that they hadn't been told, that is all the defence they need. Fire the claim in quickly and they may pay up just because it is cheaper/easier (it isn't their money after all and they can just stick a few quid more on Council Tax next year).
However if they reject your claim there may be another way to beat them...
In Scotland we have a Freedom Of Information bill. If you have something similar in England, and if you ask the right questions like "What road examinations, repairs and maintenance have been carried out at...", and "Have you had any road defects reported at .... between these dates...", and "Provide details of any claims for accidents or vehicle damage at this location, and the outcome of these claims" ) they have to answer.
It's been very interesting in my case so far - I now have it in writing that my accident was the 8th similar incident at the same place in 18 months, including a guy on a motorbike who was hospitalised. I also have it in writing from one of their road engineers to their claims department that a bollard is in the wrong place and could be moved, but they didn't! (And even if I don't win I'm thoroughly enjoying winding them up!)
The 10% +2mph was an unwritten rule of thumb the police used. Thanks to wankers like Roadpeace and Transport2000 who challenged this ruling you are quite likely to get done for 31mph in a 30mph limit. Tossers
In Herts you have to be a reasonable way over before the Gatso will go off (40mph in a 30 is the normal trigger speed from the info I was given). Herts use no dummy camera's at all if you get flashed you will get the NIP.
Never mind there is always section 2 of PACE
AJ, if the gatso is on other side of road, its funny to set it off from the opposite side.
Told my lad to smile for the camera and floored it other side of the road
His face was a picture "But it got you daddy"
