Gasket choice !! Help !!!
Old Dec 8, 2003 | 07:32 PM
Default Gasket choice !! Help !!!
What is best
Group A gasket or Comtec gasket ??
Is it worth the extra for the WRC item ??
Old Dec 8, 2003 | 09:08 PM
B11GNS's Avatar
B11GNS
Depends on the spec of your engine.
Old Dec 8, 2003 | 09:11 PM
Stage three
After bottom end is sorted i hope for around the 350bhp mark
Toe Knee's Avatar
Toe Knee
As said, group A is good, but if u can afford em the cometic are better, WRC is a bit overkill but again depends on ur spec, also the cometic are slightly thicher depending which u get so helps lower the comp ratio a bit if ur heads been a skimmed IIRC
Old Dec 8, 2003 | 09:13 PM
B11GNS's Avatar
B11GNS
Mine is similar spec to yours and i use a group A with no probs
Old Dec 9, 2003 | 09:59 AM
Ive just had this same dilemma, im going for the cometic as I think the group a's just seem to be a little over hyped and a lot of cash for what they are, and if you weigh the £150 for the cometic against the £300+ for the wrc gasket and think that it does virtually the same job I know which wins in my mind!
Old Dec 9, 2003 | 07:23 PM
Doug's Avatar
Doug
You can get a cometic tripple which is 57"Thou the same as grp A
I would personally reconmend cometic over grpA but if you got wire rung block use grp A
Regards Doug
Old Dec 9, 2003 | 07:32 PM
duno if it is right or not but i was told if you have a wire rung block then you could just use a standard gasket as it creates suficient pressure.
could be a load of bollocks though
Old Dec 9, 2003 | 07:37 PM
Doug's Avatar
Doug
Darren i spose it depends on boost and engine spec or personal preference might be wrong
Old Dec 9, 2003 | 09:17 PM
The 200 block i have is wire rung block.
Does this mean no Cometic gasket ??
Will i only be left with a group A option??
Thanks for the help so far
Old Dec 9, 2003 | 09:25 PM
now that one i dont know im afraid?
um stu where are you?
Old Dec 9, 2003 | 10:57 PM
Doug's Avatar
Doug
cozzycol,
Ive just had to have my 200 block decked for a cometic as it had been wire rung that was the advise given to me
I spose if you think about it logically a steel gasket wont compress propperly in to the groove of the ring wheras a carbon gasket will
Hope that helps
Doug
Old Dec 10, 2003 | 05:54 PM
What do you mean by decked ??????
Old Dec 10, 2003 | 06:08 PM
Toe Knee's Avatar
Toe Knee
They skim it so its flat rather than having the groves for the wire rings 2 sit in mate
IIRC dont u just need a standard gasket if u have rings due to the rings improving seal rather than a group a??
Old Dec 10, 2003 | 07:16 PM
Doug's Avatar
Doug
Toe Knee,
Cheers toe
Old Dec 11, 2003 | 05:50 PM
Anyone else got any idea if group A is best choice?
Old Dec 13, 2003 | 06:42 PM
Moose 130's Avatar
Moose 130
Aparently the late Escos FoMoCo one is better than group A. I got a Cometic one for £100 +del +vat so they arn't that dear.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
little bram
Sep 27, 2015 07:45 AM
