Heated front screen
Old Mar 1, 2006 | 10:08 PM
navigator1313's Avatar
navigator1313
Default Heated front screen
Hi,
Hope somebody can help. Need to know the following:-
What current does a heated front screen draw?
Are there 2 relays on a standard set up?
Is there a timer in the system on a standard set up?
Are there any recommendations as to how long the screen should be left on?
How long does it normally take to clear a screen that is misted up on the inside?
Reason for asking is had to put a new screen in a rally car following a re-shell and wiring that is in car is 1 relay (40A) with a + feed then splitting and going to wires on either side of the screen. This set up gets quite hot around the relay plug, and think need to have a separate relay feeding each side, but just need a bit more info before starting even more work.
Alas no heater so this item fairly vital, as found out last Saturday.
Thanx.
Old Mar 2, 2006 | 06:57 AM
steventoon's Avatar
steventoon
Should be two relays, one for each side of the screen. I think from memory its at least a 20 A fuse protecting the circuit as well.
Don't think theres a timer circuit but I could be wrong
Steve
Old Mar 2, 2006 | 07:29 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i believe that it's one single relay with in built timer. as you've found, the heating element is split into 2 halfs which a supply each side near the bottom corners.
i can't remember 100% on the relay, but i am 100% sure that it has a timer.
Old Mar 2, 2006 | 08:24 AM
steventoon's Avatar
steventoon
Ive just checked a wiring diagram, there should be two relays, one of which is a timer relay.
Old Mar 2, 2006 | 12:56 PM
foreigneRS's Avatar
foreigneRS
Testing the future
we got there in the end. big up pf
Old Mar 2, 2006 | 04:38 PM
dojj's Avatar
dojj
Resident Wrestling Legend
there are 2 relays
one if the timer
the other is the engine running one
not too sure about the fuse but i think it's more likely to be a 30 than a 20
i've got a loom at home i'll see if i can dig out when i get back to give you some proper answers
and the reason it's split driver/passenger is that even thoguh they have the same current going through them, because the drivers side is less, there is more going through and it heats up quicker
does that make sense?
should do
Old Mar 2, 2006 | 04:57 PM
pee vee's Avatar
pee vee
hmm this is interesting!!
My front screen dont seem to have a timer,,
and also only half of it seems to work properly
maybe a fooked relay?
Old Mar 2, 2006 | 05:13 PM
KSA-Cossie's Avatar
KSA-Cossie
Anyone any relays for sale ?
Old Mar 2, 2006 | 08:01 PM
dazzle740's Avatar
dazzle740
Hi guys the front screen uses just one relay noy sure if timed or not would imagine it is do to safety/overheating etc
There is two different part numbers available from ford one costs £6 ish the other £28 believe it or not
Had to replace mine and mine was the dearer of the two so phoned Paul from North Yorkshire RS Spares he sorted me one with matching part number.
Old Mar 2, 2006 | 08:07 PM
KSA-Cossie's Avatar
KSA-Cossie
Deffo has two relays one is a timer which feeds power to the other relay which in turn feeds power to the screen.
Old Mar 11, 2006 | 09:22 AM
navigator1313
Thanks to all for the info, have wired each side of the screen to a separate relay, with no timer. Will just have to remember to switch off after use!! Also found you might need to check the location of wires coming from the screen, looks as though they can get trapped by the bonet hinge - used a dab of silicone to keep out of the way.
For relays used a 40A one from the banks of those at bottom LHS footwell area, behind glove box.
When it came down to it, didn't need to use the damn thing, sunny all day, which was good for the marshals.
Roy.
Oct 9, 2015 07:38 PM
3drRich
Sep 13, 2015 07:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
YODI
Aug 30, 2015 01:12 PM
C2 MAK
Aug 20, 2015 09:46 PM
