Help cant undo sump plug......
Old Feb 24, 2006 | 07:18 PM
turbo.jon's Avatar
turbo.jon
Default Help cant undo sump plug......
Need to do an oil change on me escort turbo diesel but the bloody thread on the nut is fooked so cant undo it.i cant even get a good grip with mole grips either as the sump gets in way not like good old cvh 1s which are all flat and not weird shapes . any ideas how to get it off as it needs oil change as god knows how long the oils been in there
cheers
jon
Old Feb 24, 2006 | 07:53 PM
ellicoss's Avatar
ellicoss
Go and buy a new sump plug and knock the old one out with a chisel or if you have a welder just tack a bit of steel on it
Old Feb 24, 2006 | 07:59 PM
kevandalice's Avatar
kevandalice
take it to a garage ask them to weld a nut onto the plug. ask them to just crack it loose so you can do the oil change when you get home
Old Feb 24, 2006 | 08:03 PM
motherhupit's Avatar
motherhupit
Either weld a nut on top or get a hammer and punch and make a edge on the bolt head and use the hammer and punch to knock it around worked loads of times for me. on various things.
Old Feb 24, 2006 | 08:46 PM
turbo.jon's Avatar
turbo.jon
Cheers everyone will give them a try
Old Feb 24, 2006 | 08:52 PM
stevedohc16v's Avatar
stevedohc16v
Stillsons (pipe wrenches) work every time
Steve
Old Feb 24, 2006 | 10:56 PM
david's Avatar
david
Ive had it happen twice before on my TD mondeo
When you put the new sump plug in dont use a metal washer as thats what causing it to seize up, put a fibre one in instead and it wont be a problem again
Iain Mac
Sep 30, 2015 09:39 PM
youngben
Sep 27, 2015 09:37 PM
little bram
Sep 21, 2015 02:50 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
