water pipe routes when running turbo efi
Old Feb 15, 2006 | 08:16 PM
M K's Avatar
M K
Default water pipe routes when running turbo efi
so far i know
HEADER TANK > WATER PUMP > RADIATOR
RADIATOR > THERMOSTAT
THERMOSTAT > HEADER TANK
THERMOSTAT > HEATER MATRIX (cant remember if its top pipe or bottom it goes to tho on the matrix)
where does the other heater matrix 1 go to & the outlet in the rear of the manifold ect???
Old Feb 15, 2006 | 09:49 PM
Scottish Greg's Avatar
Scottish Greg
Just checked my Ford Technicians booklet .........
heater matrix joins with std "oil cooler" (under inlet manifold, this is the Ford item that fits onto the oil filter), to the bottom header tank pipe which leads to wider pipe from water pump into bottom of radiator
Old Feb 16, 2006 | 05:54 AM
M K's Avatar
M K
found out in another post,,,
cheers tho
EoinXR3
Sep 7, 2015 05:44 AM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
muz
Aug 16, 2015 12:57 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
yawiejon
15
Aug 9, 2015 06:36 PM
