water pipe routes when running turbo efi
so far i know
HEADER TANK > WATER PUMP > RADIATOR
RADIATOR > THERMOSTAT
THERMOSTAT > HEADER TANK
THERMOSTAT > HEATER MATRIX (cant remember if its top pipe or bottom it goes to tho on the matrix)
where does the other heater matrix 1 go to & the outlet in the rear of the manifold ect???
Just checked my Ford Technicians booklet .........
heater matrix joins with std "oil cooler" (under inlet manifold, this is the Ford item that fits onto the oil filter), to the bottom header tank pipe which leads to wider pipe from water pump into bottom of radiator
muz
16-08-2015 12:57 PM
yawiejon
15
09-08-2015 06:36 PM
