Fitness / Weight Training Discussions Don't drive around with 4 chins! Chat to like minded folk in here and get yourself back to a decent health and fitness level in no time.
Hardcore session for shocking muscles
Old Nov 10, 2005 | 08:20 PM
Paul Eggleton's Avatar
Paul Eggleton
Default Hardcore session for shocking muscles
To be done in a Tri-set fashion with no rest between sets.
Barbell Cleans - 10 x 100kgs
Squats - 10 x 100kgs
Bench press - 10 x 100kgs
The weights are an example, but you should aim to go pretty heavy.
This should be repeated 3 times with no rest at all. It will all be over within 10 minutes and then you can go home to food and bed
Make sure you warmup properly first.
Old Nov 11, 2005 | 03:07 PM
dangerous - reyland's Avatar
dangerous - reyland
How quickly would you expect to see results Paul??
Bit concerned about the squats as had cruciate ligament removed a few years back.
Old Nov 11, 2005 | 08:06 PM
Paul Eggleton
This is a one off session that should be done once a month just for fun I've tried doing it two sessions in a row, even with a rest day in between and it fucks you silly
Stick to the normal routine for consistent progress.
Old Nov 20, 2005 | 05:32 PM
lead_foot's Avatar
lead_foot
is awesome
What are barbell cleans?
Old Nov 22, 2005 | 08:19 AM
Paul Eggleton
A bit like olympic lifting(but without the press overhead). In one swift but controlled movement lift the barbell off the floor, rotating your arms to bring the bar to rest on your colar bone under your chin. Your palms end up facing the ceiling.
You then put the bar back done, again in a controlled manner.
Start reasonably light to get the correct technique.
This uses legs, back, shoulders, arms and so is very good for all the body.
Rod-Tarry
75
Oct 13, 2015 04:44 PM
SMILER258
Sep 28, 2015 09:04 AM
pabloXR
Sep 21, 2015 12:42 PM
BRAM
Sep 8, 2015 07:11 AM
