Fiesta ST This forum is for discussion of all things pertaining to the Ford Fiesta ST Range of cars.
mondeo brakes
Old Oct 14, 2015 | 09:24 AM
Neil Mcclary's Avatar
Neil Mcclary
Default mondeo brakes
Im sure this has been asked before , but what do I need to upgrade my st brakes to mk3 modeo spec.
as far as i can tell i need the following.
discs
callipers
pads
carriers
and drill out the hubs
Im staying with the stock wheels
no idea if spacers are required.
any advice would be welcome
Old Oct 14, 2015 | 04:15 PM
dojj's Avatar
dojj
Resident Wrestling Legend
st170 discs
mk3 calipers, carriers, bolts and pads
everything else fits up
the only thing is the year of fiesta as you will need to drill out the hubs from 10 to 12mm
spacers vary from car to car, some need them some don't, my mk4 didn't but the mk3 does
Old Oct 14, 2015 | 04:18 PM
Neil Mcclary
2007 st 150
Old Oct 14, 2015 | 04:45 PM
dojj's Avatar
dojj
you might not even need to drill the hubs then, whip the wheel off and remove one of the bolts to see if it's got a 17mm head and is an M10 or a 15mm head and is an M12
Old Oct 14, 2015 | 05:33 PM
Neil Mcclary
many thanks for your help
Old Oct 15, 2015 | 06:17 AM
STeve's Avatar
Super Moderator
the only pain is when using mondeo calipers and st170 discs it costs more rather than the discount of buying a single set of discs and pads for a st170 and the mondeo calipers are a bit more chunky
Old Oct 15, 2015 | 07:05 AM
Neil Mcclary
what would u recommend and where is a good place to get the parts from . the std brakes are not great
Old Oct 16, 2015 | 12:06 PM
STeve's Avatar
Super Moderator
if you have not bought them yet just buy a set of st170 front brakes as it makes life far easier, I'm out of brakes at moment but plenty on ebay
Old Oct 16, 2015 | 04:09 PM
chris cdti's Avatar
chris cdti
Ive been toying with the idea of doing this mod to the Fiesta as it needs new breaks but I think I'm going to go with the ST170 stuff.
Old Oct 16, 2015 | 06:31 PM
_Jimmy_'s Avatar
_Jimmy_
I've done this to mine with refurbished mk3 mondeo calipers and mk1 focus ST discs
When I was weighing up the options of ST170/mondeo calipers, I heard it was easier to get pads for the mondeo calipers, but don't know if that's actually true.
This guy sells a full kit with refurbed calipers for £200, which isn't bad considering by the time you've got all the bits it will cost about the same
http://www.sico-developments.co.uk/c...iant=381203548
As said above, you need to drill the hubs from 10mm bolts to take 12mm bolts (which isn't hard)
If you don't get the bolts with the calipers, ford charge £5 each for them, so I got some grade 10.9 zinc-plated ones for 50p each
No need for spacers if your wheels are the standard ST 17s (but note the spare wheel won't fit after)
Cost me £70 to do it all originally, but the first set of cheap old calipers I got siezed and warped the disc so I had to buy the whole lot again. Second time around I went for EBC 'GD' discs and greenstuff pads, here it is:
Old Oct 17, 2015 | 10:09 AM
STeve's Avatar
Super Moderator
pads are easy to get for either, better deals are to be had when buying a disc and pad kit as you cant do it with mondeo calipers as the correct discs is 5 stud so the 170 brake set up is far easier to obtain for 4 stud fitment
Old Oct 17, 2015 | 11:41 AM
Neil Mcclary
can anybody post a link to discs and pads as there seem to be loads about
Im a normal sort of driver . but the std brakes are worse than my polo,s , just want to go the simplest route with this .
many thanks for all the help in advance
Old Oct 17, 2015 | 05:39 PM
STeve's Avatar
Super Moderator
if you have st170 calipers then its these below
http://www.ebay.co.uk/itm/FORD-FOCUS...sAAMXQWzNSg6QE
or if you need calipers I have a set of st170 front calipers/carriers & bolts in stock now
but if you have already bought mondeo calipers you need to mix and match pads with discs so theres a huge choice out there
Old Oct 17, 2015 | 06:07 PM
Neil Mcclary
thats great mate ,many thanks
Old Oct 17, 2015 | 10:23 PM
_Jimmy_'s Avatar
_Jimmy_
Are the discs old? If so they might not be working at their best, and the simplest route might be to replace the standard discs and fit uprated pads, although the pads will be more expensive.
Agreed, the ST170 disc/pad combo is cheaper as you can buy them as a set. Another factor in me choosing the Mondeo calipers is I was struggling to get the ST170 ones
Old Oct 18, 2015 | 09:56 AM
philg12's Avatar
philg12
I had standard discs with m1144 pads and it made a massive difference!
Got focus rs brembos now! Yeeeee ha
Old Oct 18, 2015 | 08:30 PM
Neil Mcclary
discs and pads are all new , they stop the car but tbh very little bite to them ,got the st170 callipers and discs on the way now, my old polo was better
they have improved a bit since bedding in but are still not great on a quick car
Old Nov 14, 2015 | 03:18 PM
Neil Mcclary
OK have got my st 170 discs pads , callipers, and carriers and bolts , will i need to some spacers to aline the callipers as they are offset to fit the 150. I know I need to drill out the holes from 10 to 12 mill
Old Nov 14, 2015 | 07:58 PM
dojj's Avatar
dojj
shouldn't do, but bolt everything up first and then put on 2 wheel nuts to seat the discs too as there are varying stories about alignment
Old Nov 16, 2015 | 06:15 AM
I did this mod on my old puma. It cost me 40 quid for a pair of st17O discs and i won a complete set of calipers with nearly new pads for 45 quid including delivery. Its a good cheap mod.
Old Nov 16, 2015 | 12:41 PM
philg12's Avatar
philg12
na you dont need spacers
Old Nov 16, 2015 | 04:15 PM
Neil Mcclary
yes wheel spacers are not needed its the calliper disc spacing that im concerned about
Old Nov 16, 2015 | 04:19 PM
_Jimmy_'s Avatar
_Jimmy_
Won't be a problem with the focus ST calipers if the disc is 300mm diameter, will fit right on
The only alteration at all is the bolt holes, everything else should fit
Old Nov 16, 2015 | 04:30 PM
Neil Mcclary
thanks when I said calliper disc relationship what I should have said was do the st170 callipers have the same offset as the st ones ( as in the disc will be central between the pads ) Thanks for all your help
Old Nov 16, 2015 | 08:52 PM
Neil Mcclary
ok a little information that I have found out st150 and st170 use same calipers . but the drilling in the st170 carriers are spaced differently to allow the use of a 300mm disk so all i need to do is mount the st170 carriers and a 300mm disc, plus drill the 10mm holes out to 12mm fingers x this is right
Fordmad!
Escort MK 5 / MK 6
Nov 28, 2015 07:58 AM
Chopshop85
Oct 22, 2015 09:26 PM
wheelwizardrefurbs
Oct 16, 2015 12:25 PM
andy130
Oct 12, 2015 04:35 PM
Brickhouse
Oct 9, 2015 03:14 PM
