Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Help needed. Engine only running on 3 cylinders?
Old Nov 30, 2013 | 04:45 PM
CalXR2's Avatar
CalXR2
Default Help needed. Engine only running on 3 cylinders?
So my dad and I were cleaning the XR2's tappets out since they were so full of gunk they had gone solid. No play in them whatsoever. We've put them back in and torqued up the rocker arms, and when I fired the car back up it sounded really rough. My dad pulled out one of the spark plug leads and it didn't make any difference. One of the cylinders isn't firing at all. Anybody have any ideas as to what could be stopping the cylinder from firing?
Thanks.
Old Nov 30, 2013 | 05:04 PM
stevieturbo's Avatar
stevieturbo
C**t
Thanks.
Dodgy lead, dodgy cap, dodgy plug, dodgy lifters, dodgy valves.....dodgy anything really.
Do a compression test.
Old Nov 30, 2013 | 06:27 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Did you prime up the hydrolic lifters?
Valves not seating?
^^^^as said do a comp test
Plug? Lead? Valve stuck open?
Old Nov 30, 2013 | 06:37 PM
Which cylinder is misfiring. Swap a lead over on that cylinder so you know its not the lead. Sounds to me like its something to do with the hydraulic tappets.
Old Nov 30, 2013 | 06:40 PM
GVK.'s Avatar
GVK.
Check the lifter/rocker studs to make sure you haven't pulled one out of the head when tightening one.
(Once of course you've decided which cylinder it's missing on.)
Old Mar 1, 2014 | 05:11 PM
CalXR2's Avatar
CalXR2
We've done a compression test and its down on all 4 cylinders. The car was taken out today and given a drive 'round at 60-70mph for about 15-20 minutes. The misfire is still there, and it's the third cylinder (third from the left from driver view perspective.)
We've tried the spark plugs, HT leads, distributor cap etc... Its not any of them.
Anybody have any other ideas.
Thanks.
Old Mar 1, 2014 | 05:49 PM
martysmartie's Avatar
martysmartie
Yes, clearly it's to do with what you have done to the tappets, most likely they are knackered, thus you have bad clearances!
Also the CVH is famed for chocolate cam shafts, so you should put the tappets back in the same order.
As said, it's worth verifying the rocker is ok.
Martin
Old Mar 1, 2014 | 09:54 PM
GVK.'s Avatar
GVK.
Have you done this?
JoeyBoyden
20
Aug 22, 2015 03:23 PM
turbotrev
Aug 22, 2015 11:41 AM
Caddyshack
Aug 19, 2015 07:29 PM
ekjim
Aug 17, 2015 08:57 PM
Zoggon
Aug 10, 2015 10:39 AM
