are all cvh efi heads the same?
Old 26-02-2006 | 08:56 PM
feestk150's Avatar
feestk150
Default are all cvh efi heads the same?
im in the middle of rebuilding my fiesta turbo and hav noticed that a previous owner has converted an esc turb head for it. im not too keen on this.
ive got a head off an efi orion in stock. are they the same as the fiesta 1's?
Old 26-02-2006 | 10:59 PM
Rick's Avatar
Rick
yes they are. Nothing wrong with using the escort head either.
Old 27-02-2006 | 04:31 PM
feestk150's Avatar
feestk150
good good
cheers
Old 03-03-2006 | 07:30 PM
XR2's Avatar
XR2
No they're not! They've come with a different height. Orion EFI should be a little bit higher than FRST head, so you'll get lower compression which is better for higher boost But make sure ignition and cam timing is set to the right parameters!
EFI heads came with the injector cut outs on the inlet valves, MFI heads didn't have these!
Old 03-03-2006 | 07:40 PM
jrs's Avatar
jrs
Escort rs turbo head is diffarent to the frst head
Old 05-03-2006 | 11:51 AM
feestk150's Avatar
feestk150
the esc head that was on my car had been modified. They build up round the inlet ports with weld then machined out the holes for the injectors. Wasn't done very well tho, the gasket had very little surface area to seal onto. And to me werent cut out enough!
This is the problem with buying an already "modified" car. You just dont know what it actually is
Old 05-03-2006 | 05:00 PM
jrs's Avatar
jrs
fiesta is EFI the escort MFI the shit type
Old 05-03-2006 | 07:20 PM
SafeChav's Avatar
SafeChav
The question that was originally asked here is: Is an Orion 89/90 spec normally aspirated EFI head the same as FRST EFI head. The answer is YES
Sorry mate but your wrong The lower compression on the turbos is achieved with different pistons
Old 06-03-2006 | 01:43 AM
XR2's Avatar
XR2
Sorry mate but I'm right... Head height is different EFI <-> Turbo. Just Turbo and RSi came with the same height!
But it's right that lower compression on turbos came from lower pistons, I didn't ever say something else!
Old 06-03-2006 | 12:30 PM
SafeChav's Avatar
SafeChav
Have you looked on Ford Microcat, there is one EFI head part number for both normally aspirated and turbo. Who mentioned an RSi??? Thats MFI mate not EFI.
mk3ste
17-10-2021 10:09 AM
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
DAZZER
30-09-2015 08:43 PM
Quick Reply: are all cvh efi heads the same?
