Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Efi xr3i rough running
Old Jul 29, 2022 | 04:06 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Default Efi xr3i rough running
Hi there can anyone point me in the right direction with the issue I'm having with my xr3i efi.
the car starts and idles fine but under throttle its like hesitating and holding back. Really frustrating.
Old Jul 29, 2022 | 05:00 PM
XR2's Avatar
XR2
CVH EFI?
Is the engine running rough under throttle when the car is not moving? Then check the TPS.
If this is fine the MAP is the next thing to check. Just be careful: the early MAP work different, there's no voltage signal.
When both parts are fine check for the EDIS (as long as it's got an external one), the twin coil pack, the ignition leads and the spark plugs.
Old Jul 29, 2022 | 05:04 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Yea cvh efi, when in neutral revs freely only in gear then it struggles
Old Jul 29, 2022 | 06:51 PM
XR2's Avatar
XR2
Usually the MAP sensor. Ford used it in all EFI vehicles back in the days. Many had different part numbers but I think most of them are the same.
Old Jul 29, 2022 | 09:15 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Can you get new?
Old Jul 30, 2022 | 01:36 AM
GVK.'s Avatar
GVK.
Doubt it.
Also get a fuel pressure gauge on there should be 3 bar iirc.
Old Aug 16, 2022 | 05:36 PM
RSMK4TURBO's Avatar
RSMK4TURBO
All sorted, was fuel pump, driving like a dream now.
Old Mar 26, 2024 | 02:53 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Car was ok until recently, now in neutral it idles fine but lightly pressing throttle with revs under 2k its misses and splutters also done it when driving again light throttle under 2k.
any ideas?
ford crazy
Mar 29, 2007 04:26 PM
escort1989uk
30
Jan 3, 2005 11:32 PM
