Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
MK4 escort steering lock
Old Jan 13, 2018 | 04:52 PM
HARRY2000RS's Avatar
HARRY2000RS
Default MK4 escort steering lock
hi
i took my steering wheel off today and can’t seem to get it back on. I’ve read online that it may be something to do with the steering lock and I can’t move the key in the ignition. Any help would be much appreciated. Thanks
Old Jan 13, 2018 | 05:12 PM
haz87's Avatar
haz87
Wiggle the key in the lock. You need to disengage the key lock for the steering lock to release - then you'll be able to get the steering wheel back on.
Old Jan 13, 2018 | 05:23 PM
HARRY2000RS
I’ve tried wiggling the key but it’s just not working. I got a spanner and put it on the steering column and I was able to turn the wheels so I’m not sure what’s going on as it was fine before I took it off.
Old Jan 13, 2018 | 06:23 PM
haz87's Avatar
haz87
Without a steering wheel on the column will turn as the lock only stops the steering wheel turning, not the column/rack etc..
As said, without the key in and turned, the steering lock will not disengage and without that disengaged the steering wheel will not go back on.
Without being there its pretty difficult to suggest much more than just have a fiddle with the key barrell etc
Old Jan 13, 2018 | 07:00 PM
HARRY2000RS
Ok, is there anyway to disengage the lock? I had a good go at messing with the key but cannot get it to turn. Is there anything I can push down or turn or something to try and make it think the steering wheel is on so I can just turn the key?
Old Jan 13, 2018 | 07:15 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
try pushing the key in more , and then turning
Old Jan 13, 2018 | 07:32 PM
HARRY2000RS
I’ve tried everything with the key and it’s just not working so I’m really stuck with what to do know.
Old Jan 13, 2018 | 08:53 PM
mk2grp1's Avatar
mk2grp1
don`t panic , flip the key over 180 degrees put key in then push more in, try light pressure on the square bit at same time
Old Jan 14, 2018 | 01:10 AM
HARRY2000RS
Ok I’ll try it in the morning and Thankyou for helping me with this. What’s the square bit I need to put pressure on? Is that the silver metal peice directly underneath the steering column where the thread for the nut is?
Old Jan 14, 2018 | 11:19 AM
mk2grp1's Avatar
mk2grp1
yep , there`s nothing else but these steps ,
short of removing the complete lock and housing assembly
Old Jan 14, 2018 | 11:42 AM
Caddyshack's Avatar
Caddyshack
10 Year Member
I would have thought you need one person trying to turn on the ignition whilst you push on the lock and turn the column.
Old Jan 14, 2018 | 12:13 PM
mk2grp1's Avatar
mk2grp1
column dont need turning, the locking notches are on the steering wheel, the wheel is off
Old Jan 14, 2018 | 12:15 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Ok but he needs to take the loading off the lock...that was what I was getting at
Old Jan 14, 2018 | 12:29 PM
mk2grp1's Avatar
mk2grp1
no ,the shaft doesn`t get locked, so no loading,
it will be wobbly until the wheel and bolt are back on, it can even be removed
escort mk4 locks the wheel
Old Jan 14, 2018 | 04:57 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Forget the shaft, I meant the loading on the lock...on a normal locked column you would move the wheel to unload the lock, then turn the key....the same concept needs to be employed on the bit where the lock would fit the castlated bit on the wheel.
Old Jan 14, 2018 | 05:12 PM
mk2grp1's Avatar
mk2grp1
ok i`ll forget the shaft ,
you can`t turn the column its bolted to the car,
it would make no difference anyhow,
i did forget to ask if he had a 2 hands ,
Old Jan 15, 2018 | 12:20 PM
HARRY2000RS
Right I’ve sorted it ��.
Turns out the actual metal steering lock pin had come out and was in front of the metal stopping bar so it wouldn’t allow me to move it. Very happy now, thanks for your help guys
steve.rst
11
Feb 23, 2014 09:14 PM
atm
Feb 19, 2014 03:44 PM
Chopshop85
Mar 26, 2010 02:59 PM
loumcd
Jul 12, 2007 03:17 PM
