Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
RS1600i ignition help
Old Nov 22, 2005 | 08:37 AM
Geree's Avatar
Geree
Default RS1600i ignition help
Has anyone information about the pin arrangements of RS1600i ignitonmodul...?
I have a modul, but I could not get cabel und original twin coil to it.
Old Nov 24, 2005 | 03:12 PM
GraphiteGray's Avatar
GraphiteGray
Ive got a diagram of the ignition system showing where the wires go from the pins if thats any help to you?
http://img.photobucket.com/albums/v4...16idiagram.jpg
The RS1600i has its own ignition wiring loom seperate from the main cars wiring loom which ran from the ignition module under the dash to the twin coils and sensor on the engine. You will need this loom if your planning to run thr 1.6i setup
Old Jan 1, 2006 | 01:49 PM
Geree's Avatar
Geree
Originally Posted by GraphiteGray
Ive got a diagram of the ignition system showing where the wires go from the pins if thats any help to you? ...
Hi,
could you tell me, whether the 12V is on the pin 4? Or on the pin 3?
It is missunderstandable according to diagram.
Old Jan 5, 2006 | 08:05 AM
Geree's Avatar
Geree
Nobody? Nothing?
Old Jan 5, 2006 | 11:37 AM
GraphiteGray
Hi,
hello there
Give me a couple of days, i will check the pin wiring locations on my own RSi and then i will get back to you
Old Jan 5, 2006 | 11:40 AM
Geree's Avatar
Geree
THX 1000x!
Old Jan 5, 2006 | 08:27 PM
RSi's Avatar
RSi
12V is on Pin 4.
Old Jan 6, 2006 | 07:01 AM
Geree's Avatar
Geree
12V is on Pin 4.
Thank you very much!
Old Jun 5, 2006 | 09:02 PM
Schmidi's Avatar
Schmidi
Next question from Geree, typing by me
Where is the crank sensor located of the RS1600i?
As we found, there are no marks on the backside of the flywheel as for example on the EFI engines. I read somewhere, that there was some magnetic sign. Could you please explain it to us?
If we can't get original parts to it, is it possible to use a crank trigger kit with a 36-1 wheel, such as BurtonPower is selling?
Thanks!
Old Jun 6, 2006 | 06:21 PM
GraphiteGray
Theres supposed to be some sort of 'magnetic tooth' on the RS1600i flywheel that triggers the sensor, which is positioned in a specially machined hole on the underside of the bell housing on the RSi box. to be honest ive never seen it on my own flywheel
Its supposed to run over the sensor and trigger the sensor, which in turn sends signals to the ECU to indicate the engine speed
im not sure whether the crank trigger kit would work, but you could give it a try
Benleys
Escort Range
Sep 28, 2015 01:56 PM
beller
Sep 21, 2015 04:13 AM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
