Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Mk5 rs2000 rev counter problem
Old Apr 3, 2014 | 06:25 AM
bruny's Avatar
bruny
Default Mk5 rs2000 rev counter problem
Hi there chaps
Quick question
My rs2000 rev counter reads wrong it goes way off the dial like 12000rpm and on idle reading 2k but is at normal idle speed?does anyone might have a idea what would cause this?
Old Apr 3, 2014 | 09:14 AM
STeve's Avatar
Super Moderator
could simply be a bad connection or faulty cluster
Old Apr 4, 2014 | 02:45 AM
Poshek Fu's Avatar
Poshek Fu
Best thing is to use a multimeter in all the plugs then switch the ignition on (making sure u r properly earthed of course). It could just b a dodgy set of clocks.
Old Apr 4, 2014 | 04:13 AM
cos 4x4's Avatar
cos 4x4
Hi mate I gave a set of clocks for a mk5 out of an xr3i
Old Apr 6, 2014 | 09:49 PM
bruny's Avatar
bruny
Solved it mate.replaced the rev counter it self with a xr3 one and works spot on,swapped the white needle for the red and looks and works as it should
rex647
Mar 6, 2022 06:20 AM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
massivewangers
30
Oct 1, 2015 07:40 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
