Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Changing green ledS TO
Old Aug 18, 2010 | 03:07 PM
trev27's Avatar
trev27
Default Changing green ledS TO
ooops, messed up with the title.
LEDs can be any colour you want, the method is the same
Been meaning to do this for a while, finally got around to doing it,
cheers Alan (Albogti) who gave me some of the Led's.
This was done on my RS2K MK6, but the principal is the same i imagine
for other cars.
First of all decide what colour you want, i went for blue (original).
You will need 7 3mm blue LEDs and 7 resisters (to up the power to 12 volts), 2 for the heated front and rear screens,
2 for the front and rear fog lights, and 3 for the electric windows and boot release.
AND a lot of patience
The 8mm red Leds in picture are replacing my footwell lights BTW.
The first step is to remove the switch you want to change the colour of, here it is the fog switch, remove as shown
Disconnect the 2 plugs by pushing in a tab and release
Now the easy bit is over, the fiddly bits start. First push in the 4 tabs and release the switch from the housing,
be patient they do come out!
Then you have this once removed
Where the 2 lights meet is the earth point
Leds only work one way so make sure you get the contacts right and check before putting everything back together.
On the Leds the shorter wire is earth, another way of checking is hold the Led to the light and inside you can see
2 pieces of metal, the bigger of the 2 is the earth.
Cut and remove the Led you are removing, the one in the centre on the demister and fog switches
Place the Led and solder to the contact, shown is the led connected to the earth point
Then solder the rsister to the positive wire (does n't matter which way it goes) and then solder to the contact,
i cleaned the excess solder off before fitting
Once you are happy that it is connected proberly and all the excess solder is removed, check to make sure it works
Repeat on the other side of the switch, then do the
other 2 switches the same way, then put it all back together, very carefully then admire all your hard work
The electric window and boot release is done the same way as the above.
All the switches had the resister on the positive wire so wire the same way and you should have no problems. It is fiddly but worth it.
Once again, cheers Alan mate
Old Aug 19, 2010 | 06:27 AM
Some nice clear piccies there, you can get 12V led's in any colour also, that have built in resistors, not really any more expensive, you could also use RGB, red/green/blue led's 1 led that does these colours at the flick of a switch if someone wanted.
Must admit I've always liked blue myself as well, looks a good job, the resistor is there to drop the voltage to the diode, most are between 2.1 and 3V without resistor, depends on colour, some colours VERY expensive due to the gas used.
Old Aug 19, 2010 | 11:41 AM
trev27's Avatar
trev27
RGB ones sound good, never seen them ones
timsrs
Nov 13, 2018 11:48 AM
Kam B
Sep 24, 2015 10:40 AM
tib2220
Sep 14, 2015 12:33 PM
marky_g
Sep 12, 2015 04:26 PM
