Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Powerchip fitting guide (RS2000 MK6)
Old Mar 25, 2009 | 04:46 PM
trev27's Avatar
trev27
Default Powerchip fitting guide (RS2000 MK6)
This guide applies to a RS2K MK6, but i asume is similar for other models.
First, you need one of these. I got this for £60 which i thought was
a very good price. Ebay sell them for £95, some forums might have them for sale aswell.
Important Make sure it has the correct code or your ECU. Mine is a AFAR ecu, so i needed a powerchip/superchip programmed for that.Also, disconnect battery
before starting, so that you can reset the ecu with the chip fitted
The ECU is located in the passenger side footwell. Easy to access and
the following pictures will show the process
To remove the ECU, pull forward and it unclips out
At the oppisite end of the wiring connecter is where the chip plugs into.
So remove the cover, and there we can see the connection where the chip plugs into. Give this a bit of a wipe to remove excess paste.
Then plug the chip into it
I used a bit of tape to secure it in place, not really needed though
To fit the ECU back into its cradle you will need to remove one of the clips, so take out the cradle, which is held in place by 3 plastic nuts
Then refit everything back together
Then start the car and go for a drive.
If it does n't start or runs rough, check that the chip is fitted properly
and maybe remove some more paste on the contacts.
I found on mine there was a very noticable difference, it feels smoother
and seems to pull a lot better.
So i am very happy.
File Type: jpg
Old Mar 25, 2009 | 08:59 PM
skinnybalboa's Avatar
skinnybalboa
joel b
hey will this be the same as on a mk5 rs2000 was thinking of buying one in the near future, cheers
Old Mar 25, 2009 | 09:48 PM
trev27's Avatar
trev27
Yeah same principal. Just make sure you get the right chip for your ecu.
Old Mar 25, 2009 | 09:52 PM
skinnybalboa
joel b
thanks for the reply yeah ill make sure of that before i look for one, im actually thinking that it mite have one because ive never hit the limiter in the car in the year i have owned it???!!!! mmmmm god knows
Old Mar 25, 2009 | 10:06 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
do you do a fitting guide for door speakers? i was just looking at the routing of that cable in the door shut
Old Mar 26, 2009 | 12:20 AM
clarke5700's Avatar
clarke5700
gess not
Old Mar 26, 2009 | 04:48 PM
trev27's Avatar
trev27
Just route the cable through from inside the car through the wiring plug into the door.
Attach to speakers at one end and amp/headunit at the other.
Its an easy job mate, honest LOL
Old Dec 26, 2010 | 06:36 PM
Famous.spoon's Avatar
Famous.spoon
Can i ask where on the ecu i can identify what ecu i have? And do you know what kind of power gain you got in bhp an torque? I know its not the biggest and cleverest mod but out is betta than nout. Cheers
Old Dec 28, 2010 | 09:04 PM
stevierob's Avatar
stevierob
Hi Spoon,
Look back at earlier pics, there isa pic with ECU code near top clearly visible. AFAR. should also have some letters/numbers to identify it.
Gains are usually 10bhp/20nm torque dependant on where you get your chip/module from.
Hope that helps you mate.
Steve
Old Dec 29, 2010 | 08:33 PM
Famous.spoon
Awsum cheers steve, i think ill invest in one of these. or add it to the "todo" list for the RS lol.
Old Dec 30, 2010 | 10:20 AM
costina's Avatar
costina
Live long and prosper!!
just fit a power boost valve cheaper and does the same job
waste of money imo
Paul
Kyle Langford
27
Aug 5, 2019 07:54 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Rs_Motion
Escort MK 5 / MK 6
Jan 7, 2016 10:38 PM
mattman1234
24
Aug 1, 2015 11:46 AM
