removing sticker marks on a white van?
Old Oct 10, 2013 | 10:10 PM
matthewpickup's Avatar
matthewpickup
Default removing sticker marks on a white van?
just got another van but you can see the sticker marks on it , so is it just a case of getting stuck in with some T cut or is there a better faster way? I ask as its a mwb sprinter so quite a lot of work
any help or info would be great thanks
Old Oct 10, 2013 | 10:41 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Petrol on a rag works. Also wd40 and a bit of brake fluid on a rag has worked in the past. Then give it all a good machine polish afterwards
Old Oct 11, 2013 | 09:22 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
t-cut for a cheap fix, machine polish if you can get hold of one would be better.
Old Oct 11, 2013 | 01:41 PM
TommysKeeper's Avatar
TommysKeeper
Try Lakeland's "Sticky Stuff Remover Kit" - Gentle enough to the surface underneath but really good with the sticky residue from all sorts of different stickers. As these things always say, try it on a hidden place first.
Old Oct 15, 2013 | 09:41 PM
matthewpickup
thanks for all the replys guys, think I have worded it wrong , as it has no sticky marks its more the colour difference as the stickers were on since new so that's what I am trying to reduce
looking at machine polishers now
Old Oct 15, 2013 | 09:53 PM
tonysierra4x4's Avatar
tonysierra4x4
best way i found is 1500 grade wet and dry and t cut after. not too much rubbing though. removes slight scratching too. this does not work quite as well if lacquer has been used but great on paint finishes.
Old Oct 17, 2013 | 10:24 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Whilst colour sanding and polishing may help you will probably find the main problem is the uncovered paint has got lighter over time and the paint under the logo gas stayed original or even yellowed a touch.
I would try colour sanding a bit the using a bit of elbow grease with the t-cut before forking out wedge.
If the experiment works however order up a DA, pads and cutting compound and become a polishing god
Also if you do go full on I would start with 1500-2000-3000 polish
Old Oct 19, 2013 | 09:06 AM
matthewpickup
thanks for the info guys
I have bought some g3 stuff , tried it a little yesterday and seemed to be better than the t cut so will give that a go , but think I may be buying a machine polisher .... cut always use it on the pick up once the van is done
Old Oct 20, 2013 | 01:33 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Machine polishing will sort it
What happens is the paint under the stickers is protected,and the paint around gets scratched/swirled/fades basicly damaged
That's why you can see the outlines when stickers/logos/glue are removed
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
RSmark84
Sep 13, 2015 01:29 PM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
Bighandsuk
Sep 2, 2015 05:23 PM
