tips for polishing out scratched headlight lenses.....?
14000+ post superhero
...as title suggests anyone got any tips on whats good to use to polish out some light scratches on my headlights?
i couldnt find this thread anywhere now i know why... someone moved it to the concours section...first time ive ever been in here as im strictly a £5 jetwash once a month sort of guy......
but i got some wet and dry, could only find 1200 grit though ,some cutting compound and some polish and ill try it out tomorrow as i have plastic lenses on my work saab....
and ive still got no idea what gavin from autoglass has got to do with this unless he does jobs on the side repairing minor lense scratches with his magic window repair gel?
focus rs 1672
i done my xenons
started by wet sanding using 1500 then 2000 then 2500 then 3000.could see by this point that they were looking very good.so machined them using 3m fast cut then refined with menzerna. gtechniq c4 was used to seal them then 2 coats of coli 476.im pleased with how they turned out
before
after
its important to seal them afterwards as they will yellow as headlights come from factory with a uv coating
before
after
I've don't hundreds in Spain ass in kills the crap Renault plastics and most of the new fords as well, depending on how bad start with 800 gti then work way up to 2000 then buff with machine, or by hand takes an age tho! and same with compound finish with a super fine. and depending on customer seal them after
can you smell purple?
Location: normally dewsbury west yorkshire, but i could wake up anywhere!
Glad i found this thread, my fiesta mk6 headlights are terrible.
Question though, has anyone laquered their lights after wet/drying?
i done my xenons
before
after
before
after
Scratches on glass can be polished out but only if they are not to deep, I work in the double glazing industry and you can get small buffing pads that go in an electric drill and use jewellers rouge which they use for polishing diamonds, any good glass supplier should be able to help you with the materials but it can be time consuming, if the scratch is to deep it can distort the glass and leave a slightly concave effect.
focus rs 1672
Steve Escos
01-10-2015 06:57 AM
caprixpack
25-09-2015 07:53 PM
