Mk1 Focus RS deep clean.... Help!!
Old Mar 26, 2012 | 04:39 PM
Fezman1's Avatar
Fezman1
Default Mk1 Focus RS deep clean.... Help!!
Hi there, im wanting to give the daily mk1 focus RS a proper clean, polish wax.
I need help though... what are peolpes opinion on the best routine to get the imperial blue paintwork back to gleaming wet glossy look.????
CheeRS Fraser
Old Mar 26, 2012 | 07:08 PM
jock05's Avatar
jock05
A decent wash, clay, polish and wax.
Old Mar 26, 2012 | 07:28 PM
JamboRS's Avatar
JamboRS
focus rs 1672
do you have a machine polisher?
wash
tar remover
clay
3 stage polish(menzerna kit is good)
wet glaze 2.0
wax
if you dont have a machine polisher
wash
tar remover
clay
blackhole
wax
Old Mar 26, 2012 | 07:34 PM
Fezman1's Avatar
Fezman1
Yes, i know that but which products do you recommend?
Old Mar 26, 2012 | 07:39 PM
Fezman1's Avatar
Fezman1
wash
tar remover
clay
wet glaze 2.0
wax
wash
tar remover
clay
blackhole
wax
I dont have a machine.
What tar remover?
Which clay?
Blackhole is poorboys yeah?
Wax- nattys blue?
What i have done in the past was wash, clay, AG SRP, PB EXP, PB Nattys Blue.
Is that regime ok or waste of time.lol. results were ok.
Old Mar 26, 2012 | 08:06 PM
JamboRS's Avatar
JamboRS
focus rs 1672
What tar remover?
Which clay?
Wax- nattys blue?
tardis is a good tar remover
bilt hamber clay or megs clay kit is actually quite good
poorboys blackhole
nattys blue wax is not very durable,summer id use dodo supernatural and winter collinite
Old Mar 26, 2012 | 08:54 PM
Fezman1's Avatar
Fezman1
Is that autosmart tardis?
How often would you recommend claying the car? twice a year?
Old Mar 27, 2012 | 01:30 PM
JamboRS's Avatar
JamboRS
focus rs 1672
yes mate autosmart tardis
depends how the cars used mate,if its a daily then its going to pick up more than a weekend/summer toy
once a year is fine for a weekend/summer toy but if its a daily id do it twice a year.i do mines around april/may then again for the winter coming in around october/november
Old Mar 27, 2012 | 03:13 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
I use a power washer, followed by a hand wash using the 2 bucket method. Autogylm shampoo. Followed by claying use menza clay and dodo juice lube. That will remove 90% of the tar. At this stage you could use the tardis or the holts detarrer stuff. Hose down again at this stage.
The paint should be sliky smooth now just ready for the polishing. I recommend the Autogylm SRP polish as it's a hand polish but can be used on a D/A too. A sealent such as Autogylm EGP would protect the polish. If you get to this stage your doing very well. A waxing would usually be the last thing to do. Loads to choose from on cleanyourcar.co.uk .
Old Mar 27, 2012 | 03:30 PM
E980VTJ's Avatar
E980VTJ
use 2 buckets other wise all the dirt will go on the sponge and wiped on the car again
Old Mar 27, 2012 | 04:00 PM
Ash170990's Avatar
Ash170990
Focus RS 0268
loosen up crap with snow foam I use meguires snow foam
wash with 2 bucket method i use meguaries shampoo
Tardis to remove stubbon grime and tar
Megs clay bar with quick detailer as lube
machine polish wiht lime prime 9depends on how bad the paintwork is may need a deeper cutting compound)
then wax with dodo juice purple haze.
Old Mar 27, 2012 | 04:36 PM
Fezman1's Avatar
Fezman1
Ok. thanks.
So blackhole straight to wax- dont bother with sealant like EXP?
Or is that beacause Dodo juice supernatural is a hybrid sealant & wax
How do yo rate purple haze or blue velvet?
CheeRS Fraser
Old Mar 27, 2012 | 04:37 PM
Fezman1's Avatar
Fezman1
How do you rate purple haze? gloss/ durability?
Have you tried blue velvet?
CheeRS Fraser
Old Mar 27, 2012 | 05:20 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Never use a sponge, they are the devil and create swirll marks. Always use mircofibre cloth / wash mit.
Old Mar 27, 2012 | 07:15 PM
bassboy's Avatar
bassboy
Blue Velvet is awesome...very durable and the beading lasts a LONG time...
Personally I would recommend...
Duragloss 101 shampoo
G-techniq P1 polish (hand or machine applied)
G-techniq C1
Blue Velvet
If you want to be a bit OTT like I will be on my next detail...
Zaino Z6 after the C1
Zaino Z2pro x 3 with Z6 inbetween each layer
Zaino Z8 x 2 slightly diluted
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
massivewangers
30
Oct 1, 2015 07:40 PM
richierich1986
Sep 18, 2015 03:29 PM
JamboRS
28
Sep 14, 2015 09:02 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
