Wireless Networking
Old Sep 22, 2005 | 08:48 PM
Rob M666SCC's Avatar
Rob M666SCC
Default Wireless Networking
Ive got a Lap Top with this Centrino wireless thingy, how can i connect this to my work PC network ???????
Any links the the apropriate thingy i need would be appreciated
Old Sep 22, 2005 | 09:41 PM
xpackcapri's Avatar
xpackcapri
Old Sep 23, 2005 | 09:35 AM
DanRSturbo's Avatar
DanRSturbo
All you need to do is configer the onboard wireless adapter to connect to the work's network. As said, you'll need to know the network name, ssid etc, and also ip address's if required
Old Sep 23, 2005 | 01:56 PM
Rob M666SCC
We dont have a wireless network in the office its all wires.........
ive been told i need a wireless router
Old Sep 23, 2005 | 02:03 PM
Thrush's Avatar
Thrush
Irritating c........
Yup, your gonna need a wireless router to replace the wired one you have. YOu can still connect up the office PC's to the wireless ones using wires aswell ,so you won't need to get a hole bunch of wireless LAN cards for those.
At my work everything is done by cable, but they just plugged a wireless router in downstairs whci controls one PC by wireless, 1 laptop by wireless and we have 2 other PC's plugged in with cat 5 cable aswell...... Think it is a Netgear one, tho I don't know which model...
Old Sep 23, 2005 | 02:07 PM
EssexBoyRacer's Avatar
EssexBoyRacer
Or just get a wireless access point. Plugs into a port on u're hub/switch, set it up and u're away. No reconfiguration needed of u're wired network.
Old Sep 23, 2005 | 02:29 PM
Thrush's Avatar
Thrush
Actually, now I think about it, that might be what they have done at work?
Basically the PC plugged in to a point on the wall. SO instead of a PC connecting to the wall, this wireless router thingy (maybe it is a wireless acess point?) plugs in there, and the PC plugs in via cable into it. Then two more PC's are controlled via the wifi set up.....
Shall have to ask em Monday....
Old Sep 23, 2005 | 02:35 PM
EssexBoyRacer
Something like this would do the job.
http://www.usr-emea.com/products/p-w...-5450&loc=unkg
Plug it into u're wired network using a free port on u're hub. Configure it from a machine on u're wired network via web browser and your away.
You just set up an SSID, along with what ever security settings you want to use etc..
Its very easy!
Old Sep 23, 2005 | 02:38 PM
Thrush's Avatar
Thrush
Yes, that sounds a lot like what they have done at work. Reason was they didn't have enough LAN points downstaris for all the PC's so some are still wired and others are wireless
Old Sep 23, 2005 | 05:07 PM
Rob M666SCC
So will one of these talk to my Laptop no probs....
Sorry im useless at this stuff - i fix cars
Old Sep 23, 2005 | 05:10 PM
Thrush's Avatar
Thrush
It should talk to your laptop fine Rob, yes
Have a look here for some prices - your looking for Wireless Access Point like EssexBoyRacer said. You don't want a wireless ADLS modem router tho.
Old Sep 23, 2005 | 08:21 PM
Rob M666SCC
So could i buy something like this
http://cgi.ebay.co.uk/Motorola-WA840...QQcmdZViewItem
good old ebay
Old Sep 23, 2005 | 11:06 PM
Thrush's Avatar
Thrush
Exactly like that yes Plug that into a spare port on your modem router (if you don't have a spare port, disconnect one of the PC's plugged into it, then you will need a wireless PCi card to reconnect that PC thru the router) and plug it in, then do as EssexBoyRacer said.
Old Sep 24, 2005 | 07:45 AM
EssexBoyRacer
Wireless is a funny technology though and you certainly get what you pay for! I've used Dlink and Netgear stuff in the past with endless problems and the units completely packing up (never used motorola before)
I've currently got the US Robotics Access point in my earlier post and its been solid as a rock for months! You can get them on www.ebuyer.co.uk
Old Sep 29, 2005 | 07:08 PM
Thrush's Avatar
Thrush
Question - if I got one of these wireless access points and plugged it into the 4th port on my 4port wired router modem - how many wireless computers could I connect to it at any one time?
And for PC's/laptop's that don't have WI-FI - would this work?
http://www.ebuyer.com/customer/produ...duct_uid=48444
Old Sep 29, 2005 | 07:37 PM
EssexBoyRacer
There is a limit but its well over 200 pcs from what I remember. I think its basically down to the availiable IP addresses you can assign.
Old Sep 29, 2005 | 07:44 PM
EssexBoyRacer
yes that USB key would work but to make life easier make sure the machines are XP service pack 2!
Old Sep 29, 2005 | 08:04 PM
Thrush's Avatar
Thrush
Right, so would this work then?
Lets say I have 4 pc's, and a laptop. One PC is next to phone line socket anyway so I connect up like this;
phone line > 2port router modem. 1 port on router connected to PC via cat5 cable, 2nd port has wireless access thingy plugged into it.
Then the other 3 pc's (all running XP SP2) and the Laptop all have the USB wi-fi key plugged in, and they should all connect to my wireless access point and all "find" the net
Will this work?
Just thinking of when my bro moves into his new place, he will want BB, has 2 PC's and his missus has a laptop - so this wifi business will probably be easier than running cables everywhere, specially since all the decorating has already been done (don't think he wants to channel out the walls to run conduit and cat5 upstairs etc)
Old Sep 30, 2005 | 08:34 AM
EssexBoyRacer
yup thats fine m8. Presumably the router will be the DHCP server?
Old Sep 30, 2005 | 08:35 AM
EssexBoyRacer
Dont forget you could just use a wireless router in that situation. Most still have LAN ports so you could still connect the nearet PC by cable.
Old Sep 30, 2005 | 11:56 AM
Dan B's Avatar
Dan B
Was about to say that it'd probably be cheaper, and easier, to get a 4-port-ethernet wireless router, rather than a 4-port-ethernet non-wireless router AND a wireless access point...
I'm using the Netgear DG834G v2 at home, and my desktop (cat-5 cabled) machine and laptop (Intel Centrino Dell Latitude D800 - wireless connection from anywhere in the house) work fine together. The desktop machine has a static-assigned IP address from my block of 8, the router assigns the laptop one of the remaining 4 available via DHCP......not had a problem yet (although setting up wireless-connectivity in debian was "interesting" ).
Old Sep 30, 2005 | 12:39 PM
EssexBoyRacer
Unix man
Old Sep 30, 2005 | 05:37 PM
Dan B's Avatar
Dan B
Unix man
Just on the laptop, since I use it for work......Windows on the desktop at home, since I use that primarily for gaming!
Old Sep 30, 2005 | 08:37 PM
EssexBoyRacer
cool.
Been getting into Unix / Linux since I started working for HP.
Starting to appreciate it now after tackling a bit of BASH scripting
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
TrickyDicky
Jul 25, 2004 08:22 PM
AlexF
Jul 7, 2004 09:38 AM
