PING?
Old May 1, 2008 | 08:46 PM
RST Ski's Avatar
RST Ski
Default PING?
whats ping? i asume the higher the ping the worse lag? how can you reduce your ping?
Old May 1, 2008 | 09:04 PM
Stephen_B's Avatar
Stephen_B
I actually Bum This Place
pinging is when you connect 2 devices together via ip address
dunno about the rest
Old May 1, 2008 | 09:11 PM
fish99's Avatar
fish99
Generally a high ping means there will be lag. You will notice it if you play onlne games...its also called latency
Old May 1, 2008 | 10:56 PM
RST Ski's Avatar
RST Ski
yeh ive got high ping on a pc game, anything i can do? would spec of pc affect ping?
Old May 2, 2008 | 01:00 AM
FastFordChris's Avatar
FastFordChris
it usually means you have programs running that are interfering with your connection, things like firewalls/routers etc or if your running torrents your ping will go through the roof. turning off all unnessercary programs can also help alot.
Old May 2, 2008 | 01:38 AM
indycos's Avatar
indycos
helooooo!!!
ping pong?
Old May 2, 2008 | 08:03 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Ping is used to test whether a particular host is reachable across a network. It works by sending ICMP packet which in effect is an echo request to the target host and listening for the reply. Ping estimates the journey and response time usually in milliseconds, it will also display connectivity issues such as packet loss.
NON GEEK VERSION - FOR PEOPLE WHO NEED INSTRUCTIONS TO WORK TOASTERS !!
Ping when one system shouts down the line 'hello are you there' and another system responds with 'yes, I am here' the time sending this message and receiving it, is in it simplest form ping, if the connection is dropping and you only receive part of the message this is called packet loss
Old May 2, 2008 | 08:53 AM
BM08's Avatar
BM08
not at all, all down to connection speed, and what you have running that can be sapping some of your net speed as above
Old May 2, 2008 | 09:37 AM
stuey650's Avatar
stuey650
If you have crap ping times then you want to work out where the bottle neck is. It might not even be your internet connection, as said it could be a program sapping your connection, if your using wireless it could be between your pc and your router. If you go to command prompt and type ipconfig then hit return you will get a default gateway address. Then ping that address which will give you the ping times between your PC and your router. If its crap then you've found your problem.
DixieTheKid
11
Jun 6, 2020 11:20 AM
R5FORD
13
Dec 15, 2011 03:40 PM
