laptop cloning
Old Dec 11, 2007 | 11:52 AM
foreigneRS's Avatar
foreigneRS
Testing the future
Default laptop cloning
i have a laptop from work installed with various software such as lotus notes etc that allows me remote access in to the company server.
is it possible to clone that laptop to make a copy so that i can do exactly the same thing with another laptop?
Old Dec 11, 2007 | 12:15 PM
collierm's Avatar
collierm
MP for K.I.S.S
Use a program such as Norton Ghost to create an image of the machine. Burn it to CD, create a ghost boot disk, run and drop the image down to the new machine.
You need the machines to have pretty much the same hardware else Windows will moan about the HAL's being different and it might not boot.
See here for more info - http://ghost.radified.com/ghost_2.htm
Matt
Old Dec 11, 2007 | 12:30 PM
foreigneRS's Avatar
foreigneRS
Testing the future
collierm would that copy across all security information as well?
Old Dec 11, 2007 | 12:59 PM
ballin's Avatar
ballin
it will make an exact copy of the hard disk - so yes.
the only ball ache with ghost is finding somewhere to put the image as it is created in dos so most usb periphials aren't seen.
a second partition or hdd is the best way but not always possible
Old Dec 11, 2007 | 01:07 PM
foreigneRS's Avatar
foreigneRS
Testing the future
excellent
in theory, could i ghost the laptop hard drive and have a separate boot on a desktop to replicate it?
Old Dec 11, 2007 | 01:21 PM
ballin's Avatar
ballin
in theory yes - but remember the cloned disk will be expecting a laptop as its host. you would have to play about for a while to get it to work but like i say in theory you should be okay!
Old Dec 11, 2007 | 01:34 PM
foreigneRS's Avatar
foreigneRS
Testing the future
thanks chaps
Old Dec 11, 2007 | 04:15 PM
Adrian's Avatar
Adrian
Can be seen if you boot from it
Old Dec 11, 2007 | 08:50 PM
Eagle's Avatar
Eagle
Super Moderator
i have tried to use ghost but without much success .. the older version i got on with no problems did it quite a few times in dos...
i need to upgrade my c drive as its full of stuff now .. but last time i tried windows threw a hissy fit
i dont want to get rid of anything but moving programe files to another drive would create issues in itself i think ..
so is there an easy way to get ghost to copy the contents of one drive and put it on a bigger one ...
or will i end up with the same sized partition on the new drive and a smaller extra partition ???
Old Dec 12, 2007 | 08:56 AM
ballin's Avatar
ballin
indeed, but only if your bios supports booting from a usb device
Old Dec 12, 2007 | 08:57 AM
ballin's Avatar
ballin
if its a desktop, then put the new drive in as a slave or whatever. boot ghost to dos then just copy disk > disk. that will do exactly what you want with no partition problems.
Old Dec 29, 2007 | 05:59 PM
Eagle's Avatar
Eagle
Super Moderator
used 2004 version and what a piece of piss to do so much better than it used to be too.. now have a 320gig 16meg as opposed to a puny 60 gig
Jun 26, 2017 06:18 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Max
Nov 1, 2004 03:27 PM
Thrush
Sep 25, 2004 08:25 PM
