PC HELP NEEDED :-(....
Old Nov 27, 2007 | 12:19 PM
kenny_ka's Avatar
kenny_ka
Default PC HELP NEEDED :-(....
basically, my dvd rom wasnt workin so i fort id try and put one in there from a different computer i have...anyway i swapped them over but it didnt work and i fort i would need to get the drivers and stuff for it (couldnt be arsed )....so i put my dvd bk into my computer plugged it all in how it was b4 but now imy computer wont boot up wen i do boot it up it comes up
"Pri Slave Drive - ATAPI Incompatible
Press F1 To Resume"
wen i press f1 it goes to the windows xp screen and that is it
any help will be appreciated
Old Nov 27, 2007 | 12:25 PM
DaveZS's Avatar
DaveZS
Better use my strong hand
Does your pc load up without it plugged in?
You haven't removed any jumpers out the back of the dvd drive have you? Sure your using the same ide cable that was plugged in before?
Old Nov 27, 2007 | 12:28 PM
kenny_ka's Avatar
kenny_ka
jus tried an it dont load up wen it aint plugged in, im usin the same cable as b4 cos id idnt even take it out, there is 2 plugs on the same cable tho but i tried them both.......i assume its the dvd drive thats stoppin it from workin cos thats the only thing i have touched inside it?
Old Nov 27, 2007 | 12:30 PM
kenny_ka's Avatar
kenny_ka
sorry it does load up wen its not plugged in
Old Nov 27, 2007 | 12:36 PM
MK5RST's Avatar
MK5RST
Jumpers then, set your jumpers on the cd drive to slave
Old Nov 27, 2007 | 12:39 PM
kenny_ka's Avatar
kenny_ka
how do i go about doin that
Old Nov 27, 2007 | 12:40 PM
DaveZS's Avatar
DaveZS
Load up your bios (press delete when your pc loads up) with them plugged in and see what it lists as primary master/slave and secondary master/slave.
Not big problem mate, you've just got a setting wrong somewhere
For the jumpers, look at the back of the drive where the cables go in. You should see a little black block sticking on some small pins. Have a look what ones its on
Old Nov 27, 2007 | 12:43 PM
MK5RST's Avatar
MK5RST
On the back of the cd drive next to where it plugs in there will be some pins with a black thing accross, change that to slave, also check u havent bent any pins!
Old Nov 27, 2007 | 12:53 PM
kenny_ka's Avatar
kenny_ka
these r the cables i have but they both have 2 plugs on then so which one of ach should i plug in ?
thanks for the help guys
Old Nov 27, 2007 | 12:54 PM
kenny_ka's Avatar
kenny_ka
surely that dnt need changin as i didnt change it b4?
Old Nov 27, 2007 | 12:55 PM
ballin's Avatar
ballin
the first cable you have shown is just the power (the coloured one) so use either.
The second cable (ribbon cable) is the one you need to make sure if the same as before. It shouldn't really matter unless you are on cable select, dont worry about the terminology, just try using either of those connectors, do both fail?
Old Nov 27, 2007 | 12:58 PM
Smit's Avatar
Smit
The 60ft Launch King
You with have 8/10 pins on the top/back of each unit. There should be a diagram on how to make them master + Slave as they both won't work until they are on different settings! It's a little black piece of plastic with a metal connector inside. They slide over 2 of the 8/10 pins to tell the motherboard what's going on... They both have to be different. Just look at the sticker on the unit its-self..
Old Nov 27, 2007 | 01:04 PM
kenny_ka's Avatar
kenny_ka
so wot hould the lil plasti thing be on? i jus changed it from master to slave i booted up the computer and it came up in red bold writing
"!!!!!!!!!!!!!IDE DRIVES INTALLATON ERROR!!!!!!!!!!!!!"
Old Nov 27, 2007 | 01:13 PM
kenny_ka's Avatar
kenny_ka
dnt ask how but i done it lol thanks for the help guys
Old Nov 27, 2007 | 01:25 PM
DaveZS's Avatar
DaveZS
Old Nov 27, 2007 | 01:59 PM
BM08's Avatar
BM08
How the hell can you mess up removing one/two plugs and putting them back dont bother trying to install anything else for god sake, it might not be good for your health
Old Nov 27, 2007 | 02:02 PM
Smit's Avatar
Smit
Master is always the hard-drive! Slave can be anything.... 2nd hard drive dvd drive anything...!
Remember to change the settings in BIOS when you boot up to tell the computer what is what..
Old Nov 27, 2007 | 02:05 PM
kenny_ka's Avatar
kenny_ka
no need for that
Billy_RS
16
Oct 11, 2025 09:41 PM
skypeller
Sep 19, 2015 09:58 PM
borboyous
Aug 22, 2015 11:17 AM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
col93saphcos
Aug 7, 2015 03:21 PM
