over clocking
Old Mar 24, 2007 | 09:39 PM
djmillsy's Avatar
djmillsy
Fife Radge
Default over clocking
what is it and why would i do it to my computer
Old Mar 24, 2007 | 10:54 PM
BM08's Avatar
BM08
Ive never done it myself/nor needed to, but basically what it is without going into too much detail is making your cpu(processor) run slightly faster, it depends what processor you have as to whether or not its a piece of cake or slightly harder, and some cpu's dont overclock very well, where as some overclock nearly twice the speed it normally runs at.
If you want a more detailed description then look at this thread on this site, it tells you everything http://www.tech-forums.net/pc/f10/ov...e-guide-20319/
Hope that helps
Old Mar 24, 2007 | 10:55 PM
BM08's Avatar
BM08
By the way what pc do you have now?
Old Mar 24, 2007 | 11:52 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
im a moderator on one of the largest overclocking websites and forums on the net (overclockers.com and ocforums.com)
As stated its basically the art of making a computer run faster than it is supposed to. It is similar to modifying a vehicle in as much as to do it right and to get it to hold together is not cheap.
Ive been clocking now for 14 years and started because I could not afford a PC fast enough as I would have liked, back in the day computers were very expensive.
Now computers are as cheap as toasters the need to overclock has rather deminished and as such I now have many systems which have the power I require that are not overclocked.
Having said that however I do still own a overvolted, refrigerated system with very high performance quality components with a processor speed of 5ghz... its not needed though to be honest
Old Mar 25, 2007 | 11:48 AM
djmillsy's Avatar
djmillsy
Fife Radge
so is it worthwhile doing it to a 1.8 ghz amd processor and is it cheap
Old Mar 25, 2007 | 02:17 PM
Turbocabbie
Top Cab !!
I would personally overclock a 1.8 simply because the system will be worth not a great deal....
If its a 1.8 Intel run a big fan and jack the FSB as high as you can.
if its a AMD unlock the processor, drop the mulitplier a little and jack up the FSB to increase bandwidth across the board.. I would also personally run a large heatsink on this and overvolt it a little.
The stability of these systems overclocked would by large depend upon the quality of the components, specially the memory and PSU
The big question to ask in reality is can you afford to kill the system? - over clocking does stress components and if you have cheap shit it will fail when pushed
1.8ghz systems clocked on air generally make around 2.5ghz in my experience with the right bits
Old Mar 25, 2007 | 02:44 PM
djmillsy's Avatar
djmillsy
Fife Radge
i think ill pass on that then just wanted to know what it was thats all
Old Mar 25, 2007 | 07:12 PM
Drewman's Avatar
Drewman
I recently tried overclocking and I got my 1.8 athlon running at just over 2.1, I tried a bit higher but I don't think my PC liked it as I got a System Boot failure
I shat myself
Old Mar 25, 2007 | 07:31 PM
djmillsy's Avatar
djmillsy
Fife Radge
I shat myself
Old Mar 26, 2007 | 07:54 AM
DanRSturbo's Avatar
DanRSturbo
I shat myself
ROFL
The risk of overclocking is always the big bang
Old Mar 26, 2007 | 10:01 AM
Turbocabbie
Top Cab !!
The amount of systems I have lost when the pumps have packed up or leaked on my watercooled rigs
Old Mar 26, 2007 | 12:59 PM
BM08's Avatar
BM08
This is why i always buy(especially nowa days) a system thats fast enough without overclocking.
For example i have a Dual core AMD 4200 which i got almost a year ago, and a year ago this was an extremely fast processor and would beat most processors back then, and now a year on ok it will get beat by a fair few Intel processors BUT its still quick enough for everyday tasks and also i can still play the top games at playable speeds on max settings(pretty much most games)
Old Mar 26, 2007 | 01:01 PM
BM08's Avatar
BM08
djmillsy for a cheap upgrade in speed you could get a new processor for under Ł100, as long as the processor is compatible with your motherboard you'll be laughing
Old Mar 26, 2007 | 01:27 PM
Turbocabbie
Top Cab !!
mobile processors overclock the best as they are designed to run on lower voltages so when in a desktop motherboard effectively get a voltage jump which makes them more stable when clocked
Old Mar 26, 2007 | 02:54 PM
BM08's Avatar
BM08
Didnt know that
Mark_
14
Jan 16, 2016 05:27 PM
cossie brad
Sep 29, 2015 02:38 PM
Mr S1
20
Sep 27, 2015 04:06 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
